Launch control for Motronic
  • prj
    • Mar 2010
    • 6308
    Originally posted by Rocco
    YOU ARE HAVING MUCH MORE GOOD LUCK THAN ME BY FAR
    And Simons...
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      #227
      Finally...
      ...YES!
      But don't worry Tómas. Sure your 2 machines will be work fine
      photobucket SUCKS
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #228
        Originally posted by M_GORDON
        Finally...
        ...YES!
        yes you said "WILL"
        • M_GORDON
          • Oct 2008
          • 1295
          #229
          yes you said "WILL"
          Yes, will. Because NOW don't is perfect.
          But I want your not perfect to me
          photobucket SUCKS
            #230
            Hey guys... try to keep this thread on topic please !
            • M_GORDON
              • Oct 2008
              • 1295
              #231
              Excuse me
              photobucket SUCKS
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #232
                please Paul,delete all these waste of time and offtopic posts here
                sorry,today was not a very good day for me
                • mc1
                  • Aug 2009
                  • 76
                  whats the best harness to use
                  Quick question ... I have U S model coupe 1990 . I am planning to put a 20v turbo motor in place of the stock one . My question is..... i have found a low milage motor from an s6 from canada. What is the best wireing harness to use which will be the least amount of a pain. Also would this motor be an aan set up? Thanks
                  • driftin jo
                    • Sep 2007
                    • 2222
                    The AAN harness .
                    • andy10v
                      • 5996
                      Engine from an s6 will be an AAN
                      Easiest harness would be a left hand drive s2 aby I would have thought as its small chassis and cop.
                      Sold ABY-stock
                        #236
                        This is off topic really but yes - LHD ABY harness is the easiest way to go for transplant into a B3 Coupe
                        • HPmuirt
                          S2Forum April Fool
                          • Apr 2005
                          • 3014
                          #237
                          On topic Paul: What are the chances of getting in on this VLC shindig, as per my recent PM?
                          Cheers n
                          Si
                          Subtle mods here and there
                          2011 A5 3.0 TDi - Lava Grey
                            #238
                            Will pm you back ASAP - the lovely linear idea isn't working just yet but it's perfectly usable without it - unless you want to fine adjust at silly high revs
                            • BennyBoo
                              • May 2011
                              • 67
                              I run a WOTBOX..
                              It cuts ignition at a user set rev limit so it builds boost, also has the option to 'no lift shift'
                              I love it, and the pops and bangs when shifting make me smile...
                              Scruff4 Lag Monster Noggy.
                              In Progress:
                              Volvo K24-7400/7000 hybrids, 2.4 heads, RS4 Rods, Tial W/G's + Screamers, True Dual 2.5" straight pipes :twisted:
                              • prj
                                • Mar 2010
                                • 6308
                                Originally posted by BennyBoo
                                I run a WOTBOX..
                                So?
                                I can guarantee you that your turbo and exhaust manifold do not smile when you dump fuel into the manifold.
                                The no-lift shift does not take into account gear ratios either, just a delay.
                                I can do ignition retard as easy as 1-2-3 in Motronic, but I choose not to, because safety is more important and it's good enough without, and it easily builds boost as well, which you would have known, if you'd bother to read the thread.
                                Not to mention the wotbox costs 200$ before shipping and VAT, and requires running all the ignition wires to it, altering the harness etc... while this is plug and play.
                                So what is the point of your post?
                                Trolling? Advertising? Take it elsewhere.
