Modifying Motronic 2.3.2 ECU hardware and software.
This topic is closed.
  • kaross
    • Oct 2010
    • 22
    • Country: Latvia
    #76
    he wont do it.
    I was asking info for money.
    But now I have find a lot by myself. Now just need to find KRKTE.
    • stocious
      • Jul 2012
      • 838
      Try here
      Nefariousmotorsport.com
      Maybe in there somewhere !
      Good luck !
      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
      • kaross
        • Oct 2010
        • 22
        • Country: Latvia
        #78
        yes, I am also in this forum. Why are you mentioning it?
        I don't think that much people know KRKTE for his M2.3.2 ECU.
        • pasbogdan
          • Sep 2009
          • 1160
          • Country: Romania
          #79
          Good luck !
          On that forum i found old info that i learned long time ago
          xx = 16Bit Checksum of the complete binary file
          yy = binary complement of xx => FFFF - xx
          zz is an internal Bosch build number of the file
          Here different examples for the last 6 Bytes (xx yy zz):
          Audi S2 - ABY - M2.3.2
          895907551A - 0261203145 - 1267357519
          ...F9 D9 06 26 A1 47 => FFFF - F9D9 = 0626
          Audi S6 - AAN - M2.3.2
          4A0907551C - 0261203601 - 1267358644
          ...0A 96 F5 69 A2 45 => FFFF - 0A96 = F569
          Audi RS2 - ADU - M2.3.2
          8A0907551C - 0261203543 - 1267358647
          ...AA 37 55 C8 A2 53 => FFFF - AA37 = 55C8
          Am i to afraid or you have to be born for something like this?
          • stocious
            • Jul 2012
            • 838
            It has to be in your blood like oil in ours
            Interesting all the same over there
            • stocious
              • Jul 2012
              • 838
              Originally posted by kaross
              he wont do it.
              Excuse me if I misunderstand ! I thought Krkte could be obtained with a formula,
              Which is why I posted the link.
              Good luck with your work !
              • kaross
                • Oct 2010
                • 22
                • Country: Latvia
                #82
                Yes, KRKTE can be obtained by formula, but I need to know where I can correct it in ECU bin file. Basically it is injector constant.
                KRKTE is a constant which converts the required fuel mass to be injected into a duration in milliseconds which the fuel injectors are to be switched on for injector pulse witdh. This value is calibrated for the stock fuel injectors and fuel pump so if uprated injectors are fitted, it will need to be recalibrated.
                easiest way is to calibrate fuel map, but it is not the right way. mostly fueling will be wrong. I want to do it in right way like PRJ.
                • vwnut8392
                  • Jul 2012
                  • 418
                  For all you guys still working hard at this i stumbled across a really cool site with aolt of great motronic information.
                  Take a look at this PDF for Motronic 4.3, they give tons of info about the inner workings of this version including some good examples of how to use programs like idapro to find certain functions in the ECU. I feel motronic is motronic no matter what its running so you could get an idea of how to go about digging deeper into our ECU's.
                  "The really good drivers got the bugs on the side windows." Walter Röhrl
                  • kaross
                    • Oct 2010
                    • 22
                    • Country: Latvia
                    #84
                    any new here?
                    • vwnut8392
                      • Jul 2012
                      • 418
                      i havnt been working on it lately, my car blew up so i tossed it behind the garage for now and i've been playing with megasquirt in a turbo E30 BMW.
                      • ba6nokia
                        • Mar 2013
                        • 1
                        you blew up AAN?
                        Maybe better not playing with Motronic.
                          Oooo...Tell us more.
                          • vwnut8392
                            • Jul 2012
                            • 418
                            was out hammering on it and it spun a rod bearing. just ordered ACL calico coated rod and main bearings, wagner sport quattro manifold, precision billet 6265 turbo, ARP head stud kit, autoverdi rod's, ARP main bolts, head is out being CNC ported, radial valve job, 034 metal headgasket for now. im trying to decide weather to go with high rev valve springs and all the titanium goodies in the valve train or to just go solid lifter and shoot for 10,000 RPM plus what cams i want to run. bought VEMS for my car now too now anyhow, i think the lack of being able to tune the motronic is part of why it blew up because the bearings show detonation. well its time to make some real power as im shooting for 700 wheel. cant wait to see the next fool who makes fun on this 4000 quattro.
                            • Ur20V
                              • Jan 2011
                              • 9
                              Can anyone identify the MAP sensor in this photo?
                              Is it simply a Freescale 6300 or 6400?
                                Certainly doesn't look like the Freescale MAP sensor that EFI Express offers:
                                http://www.efiexpress.com/catalog/pr...products_id=82
