Oh Deer! (new bomb?)
This is a sticky topic.
  • Rusty
    • 18953
    Well, whilst driving into work this morning, I was about 6 inches from having one of those new-fangled Deer to air intercoolers on the front of the S2. I'm not sure what the specific heat of Deer is so decided to swear VERY loudly and slam on the brakes to avoid the aforementioned modification occuring.
    I'm sure that and emergency stop is in the bedding in instructions for the new pads that I've just fitted, so I'm glad that I've got that out the way...
    Anyway, the reason for posting in the 'brakes section' is that just after all this occuring, the autocheck started beeping and flashing the brake warning. This struck me as not being ideal, although missing the Deer most definitely was ideal . Tried another emergeny stop a bit further down the road just to see if it would do it again... and it did.
    Therefore, I think it's new bomb time in the near future. Where's a good value place to get it from?
  • iain1067
    • 984
    Paul @custom autocraft, cheapest by miles i am pretty sure it's the same part as urs6
    Iain
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      Let me know if you find one cheap Andy.My bomb's been knackered for a while now.
      The car's also done 2 laps of the Nürburgring and 6 laps of Castle Combe with the red "Achtung!" warning flashing. You just have to push the brake pedal a bit harder.
      SS
      • nigelm
        • 150
        bomb
        Try FEBI
        SOLUTIONS DRIVEN BY YOU ✔ Maßgeschneiderte Lösungen für Handel und Werkstatt ✔ Qualität seit mehr als 175 Jahren ✔ Mehr als 47.000 Ersatzteile ✔ Weltweite Verfügbarkeit ✔ Eigene Produktion
        The FEBI site lists the part no as 14176
        Dunno the price but could be cheap.
        nigelm
        • topsparky
          • Oct 2005
          • 2014
          check your power steering fliud level aswell mine did this and because the level
          was not on max as i braked heavy level went below minimum
          and up flashed the auto check
          unless my bomb is knackered too
          1. SHORT SHIFT KIT
          2. PORSCHE CAYENNE CALIPERS
          3. H & R SPRINGS
          4. BILSTEIN SHOXS
          5. NEW BUSHES AND HP2 STRUTS
          6. UPRATED HIGH OUTPUT COIL PACK
          7. ,3" turbo back s/s/ exhaust
          8. fmic fitted
            Strange that, my car has started doing the same in the last couple of days.
            • stevieyid
              • Apr 2005
              • 2251
              I think i read on here that it could be down to the cold weather affecting the pressure. Could this be right? Cant find the thread now
              • Fat Audi 80
                • 10547
                Before you get too excited and spend more money have you tested the bomb??
                Switch off.
                Pump brake pedal fully counting the number of times you can do it before the pedal goes hard
                Any number over 30 and your bomb should be find.
                Check S2central for more info.
                I have had the (!) upon startup for three years now, although never bomb related (!) while driving.
                If you get the (!) while driving check your Brake fluid level and sensor and more likely (in my case anyway) check the PS fluid level and the sensor.
                The wiring to my PS fluid level sensor can be flaky and throw a (!) every now and again...
                Good luck
                Cheers,
                steve.
                The Perfectionist
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Hi jinks mines started ( ! ) in the cold mornings but i tested the stoping power and it put my face on the wind screen
                  Its got to be down to this cold spell
                  Chef
                  • iain1067
                    • 984
                    a hard brake pedal as well even when driving???
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      If the PAS belt comes loose or slips, there is no immediately no assistance for brakes or steering. BTDT.
                      I seems strange driving another S2 that has a working bomb, I nearly go through the windscreen when I rest my foot on the brake pedal.
                      That's what mine used to be like, but it's getting hard work trying to stop now.
                      SS
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        I think i will have a go at Steves test, pump it 30 times and also check the fluid levels.
                        How much is a new bomb or do i not want to no?
                        Chef
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          You don't want to know.
                          Que Parts Daddy:
                          SS
                          • s2avant
                            • 2426
                            Did somebody call me? Is there an S2 in distress? Never fear Daddies here :mischeif:
                            A new bomb retails at £322.40 inc VAT
                            There is a fairly good discount code on them though. Group Buy anyone?
                            Ben
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              Originally posted by nigelm
                              Try FEBI
                              nigelm
                              I don't think that P/N is right. It lists it as 443 612 061 H.
                              SS
