Brake bomb replacement
  • John.
    • 2615
    Originally posted by psiconauta911
    Mine are with alu washers and are fine.
    7zap indicates what seems like O-rings but no grooves on mine and had washers from factory
    I worked at a Citroen garage back in the day, it was definitely a rubber sealing ring used on their "spheres". I would think if it doesn't have a groove to locate a seal then a washer of some sort would be a better idea?
      • Dec 2017
      • 5983
      Thank you Lago. That is just what I needed. My search of the forum had failed to find your second post. Anyway, small confession, I do have o rings. They are concealed in the fitting on the hose end. When I removed the bomb, it wasn't in good light and I wrapped the hose end fitting in a clean cloth to stop any dirt getting in there. I just went for another look, and there they are!
      So, I need two of these new o ring seals. A quick search online and they are available in Latvia. I can get silicone o rings of the correct size in the UK. Will they be ok? I will ring TPS tomorrow but I'm not holding out much hope. Anyone have a couple of new ones knocking about?
      And, following the guide Lago posted, cleaned out my fluid reservoir. Yuk, lots of black stuff in the filter And I put new fluid in when I did my 're build. I suspect the diaphragm on the bomb is breaking down
        The diaphragm has to be split to leak the nitrogen back into the system.
          • Dec 2017
          • 5983
          Yes, I'm thinking the same. The garage I have sent it to say they test it first before they try and 're gas it. If the diaphragm is broken, it can't be repaired. Some of the Citroen ones can be taken apart and a new diaphragm inserted but apparently not these.
            • Dec 2017
            • 5983
            The seals are still available from Audi
            n90405401
            I've ordered two and 2 litres of G00
            Whilst waiting I've drained all the old oil and cleaned up the reservoir.
            • Monkeymagic
              • Mar 2012
              • 3419
              A broken diaphragm can be costly.....
                • Dec 2017
                • 5983
                My bomb has been successfully repaired by these guys.
                Pleiades Garage, Unit 12A, Brookside Ind Estate, Sawtry, Huntingdon. PE28 5SB. Tel 01487831239
                Ask for Phil.
                Total cost with postage was £96.
                They drill into the bomb, fit a valve and 're charge it to the correct pressure with nitrogen.
                • SteveH
                  • 4460
                  Result
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • larsaskogstad
                    • May 2020
                    • 674
                    • Country: Norway
                    #24
                    The bombs are usually at discount on autodoc up to 32%+ , Got a new one for around 200£ . ( 4A0612061D )
                    https://www.s2forum.com/forum/member...-3b-1991-coupe
                      Ask for Phil.
                      Strange, so I wonder what broke?
                        • Dec 2017
                        • 5983
                        Nothing broken as such. Apparently the nitrogen gas slowly discharges over time. I should be good for another 7 years now.
                          • Dec 2017
                          • 5983
                          My refurbished bomb turned up today and I must say I’m very impressed. They had totally refurbished it with new paint! Looks like a new one.
                          All fitted no issues with two new seals on the banjo bolt. The screen on the banjo was quite grubby and that was cleaned out. New fluid and bled everything and it's all working perfectly.
                          • Michael S2
                            • Dec 2011
                            • 1378
                            Great to hear definitively that these can in fact be repaired. Thanks for sharing
                            1995 Audi S2 Avant
                              Great result Dave
