Originally posted by psiconauta911
View Post
Brake bomb replacement
Thank you Lago. That is just what I needed. My search of the forum had failed to find your second post. Anyway, small confession, I do have o rings. They are concealed in the fitting on the hose end. When I removed the bomb, it wasn't in good light and I wrapped the hose end fitting in a clean cloth to stop any dirt getting in there. I just went for another look, and there they are!
So, I need two of these new o ring seals. A quick search online and they are available in Latvia. I can get silicone o rings of the correct size in the UK. Will they be ok? I will ring TPS tomorrow but I'm not holding out much hope. Anyone have a couple of new ones knocking about?
And, following the guide Lago posted, cleaned out my fluid reservoir. Yuk, lots of black stuff in the filter And I put new fluid in when I did my 're build. I suspect the diaphragm on the bomb is breaking downNothelle S2 Avant
The diaphragm has to be split to leak the nitrogen back into the system.
Originally posted by newsh View PostThe diaphragm has to be split to leak the nitrogen back into the system.Nothelle S2 Avant
My bomb has been successfully repaired by these guys.
Pleiades Garage, Unit 12A, Brookside Ind Estate, Sawtry, Huntingdon. PE28 5SB. Tel 01487831239
Ask for Phil.
Total cost with postage was £96.
They drill into the bomb, fit a valve and 're charge it to the correct pressure with nitrogen.Nothelle S2 Avant
Originally posted by Tractor Dave View PostMy bomb has been successfully repaired by these guys.
Ask for Phil.
My refurbished bomb turned up today and I must say I’m very impressed. They had totally refurbished it with new paint! Looks like a new one.
All fitted no issues with two new seals on the banjo bolt. The screen on the banjo was quite grubby and that was cleaned out. New fluid and bled everything and it's all working perfectly.
Sent from my iPhone using TapatalkNothelle S2 Avant
- 3 likes
Great result Dave
