ok alex thanks for that reasons seem more explanitory now. no parts or mega wonga.
so what makes the b3 plug and play and not the s2? all the s2 parts fit the b3 pedal box?
is there a b3 thread to stop me butting in on this one?
Hydraulic to Vaccum servo conversion
This is a sticky topic.
OEM B3 pedal box profile:
Modified pedal box and bulkhead profile:
Spacer plate:
Assembly:
The bellows on the D3 servo is ~60mm. The hole in the B3 bulkhead is ~45mm. It won't fit without modifying the bulkhead and the pedal box. On RHD the D3 servo won't mount directly to the bulkhead either you need to use a spacer or the servo body hits the bulkhead, due to the profile. Trust me I have all the parts here
Nice work Horsty
I tried this on RHD with a D3 servo (same size/fitting) but it doesn't fit, there is not enough room for the master cylinder.
I am working on a adapter plate to mount the servo directly to the bulkhead. The bulkhead and pedal box need to be modified to allow the larger 60mm bellow to fit through. Even then I don't think it will work with the standard ABY/3B/RS2 intake pipe, reverse intake will be needed I think. I am going to use the 26.9mm master cylinder too
If you mount the booster directly to the bulkhead the complete setup will be about an inch shorter then std so should fit oem intake also on RHD models. It was no problem on LHD except you need to raise the booster a bit from std center to clear tha banjo on the steering rack and you need to reroute the cable loom in the engine bay. Just fitted this setup to my CQ
Do you have a picture of the assembly installed on your car Horsty?
B3 setup is bolt-on Gaz, it's a real easy swap
Vac servo used are about £50. New £200.
Single stage PAS pump is more reliable (you can't buy genuine ZF rebuild kits for the S2 pump anymore) plus they are common to loads of cars inc Porsche so there will never be a parts availability problem with them, likewise the vac servo.
S2 hydro servo is around £900 from memory. Bomb is £250 and has a finite life, they are NLA too afaik. Try and get a decent dual stage S2 PAS pump, almost impossible! Plenty of practical reasons.
I'm going to upgrade again to the D3 V10 servo for better line pressure from the dual diaphragm booster, and the better pedal feel of a larger MC.
i dont suffer any of those issues, even with 6 pots, i dont need more power than that!
i can imagine the s2 pump not being cheap though. neither is custom machining and sourcing other parts though.
still not convinced but enough do it so ill take your word for it. interesting stuff and well worked out either way.Leave a comment:
the original hydraulic brake booster is way to expensive.
especially when you have to repair it.
i got rid of the hydraulic stuff.
advantages:
- servo pump is cheeper
- hydraulic steering lines are cheeper
- more brake power
- lighter in total
- you dont have to press the brake pedal so hard anymore
(you can compare the pedal pressure almost to the gaspedal pressure)Leave a comment:
seems a lot of work.
why not just use the factory bomb setup? what makes it worth the effort?Leave a comment:
Nice work Horsty
I ended up buying an RS6 one way valve. It's much better but I'll be fitting a bigger servo soon.
MGLeave a comment:
Hi Guys,
sometime last year i fitted the a8 d2 brake booster and master brake cylinder in my 7A quattro coupe and i thought it might be interesting for one or the other...
7x8 inch brake booster combined with the 25,4mm master brake cylinder.
the other option would be the 26,9mm i guess. but that would be overkill.
adapter plate needs to be fabricated. otherwise the brake booster will be leaky.
a6 v6 hydraulic steering pump. quite the same pump used for a long time at audi.
a4 b5/b6 or B4 v6 is also the same. bolt on directly to the 7A bracket.
brake booster without grommet. you see these tubes coming out of the brake booster for the bolts.
the "tubes" are not the same level as the brake booster surface. thats the reason for the adapter plate i made.
adapter plate alignment.
difference between the hydraulic spacer (short one) and the vacuum spacer (long one).
adapter rod and the grommet mounted.
adapter plate, vacuum spacer, adapter rod and that kind of fork mounted.
this adapter needs to be fabricated to increase the rod length:
ready for installation:
Yes the thread is larger on the servo pushrod, M10 vs M8 so an adapter is needed
