Hydraulic to Vaccum servo conversion
This is a sticky topic.
  • diesel des
    replied
    The rubber o ring? It's fine and I have it together with rubber grease. Just started the car and it's making a squealing noise around the brake peddle so the servo must be nackered. Ffs. Out again! Now need to find another one. Ahhhhh.
    replied
    Did you forget the seal between the BMC and the servo?
  • diesel des
    replied
    Right got the brake fittings but now some more issues. So the nipple is broke on the resovior for the clutch master cylinder feed so have another on order. Can't bleed the brakes until that's done.
    My next issue is that I'm testing the servo by sucking on the vacume feed pipe and i cant draw any vacume much. I hear it leaking away some place. I take it that's not right?
    replied
  • diesel des
    replied
    Cool. At least I know what I'm asking for at the parts place.
    replied
    Yes the fittings and pipes to the ABS unit are larger with the larger master cylinder. M12 fine, you can buy these oversize fittings for standard 3/16 pipe
  • diesel des
    replied
    Also anyone know if the strut brace fits ok on the urs4 with s8 setup?
  • diesel des
    replied
    I started fitting a s8 setup to my urs4. Pain lying upside down under the dash trying to get a 4 x m8 bolts yiu can barely see or feel. Anyhow I made an adapter rod about 30mm longer than stock and it's still a bit short. I need to take it back out and make 1 about 50 mm longer than stock approx.
    My next issue is that the brake pipes are a different fitting on the s8 master cylinder. They seem to be m12 fine thread as apposed to the stock m10 fine. So I need to sort that. I also swapped the pump for a single 120 bar single.
    Hope it makes a good difference to the brakes vs the hydraulic setup with a tired bomb.
    replied
    Ah, I see. Not dissatisfied with mine at the most so all good
    replied
    Yes, 26.9mm. But only to fit the dual diaphragm booster afaik
    replied
    Is there a larger cylinder than an ABY one?
    replied
    Originally posted by GazzaG60
    im confused in your other post you say b3 setup is bolt on. is it just a matter of getting the bits or is it custom piston and spacer work too?
    i need to do some reading i think to understand the setup more. seems quite a few have done it. i hope my brakes still works as it used to do. otherwise ill need to read more carefully.
    edit
    so after reading the d3 is too big for stock fitment,
    alex - is the audi cab one is direct fit? are you using that if not is there a reason why you went to the trouble of adapting the setup for the d3?
    the rest seems straight forward and i can see why its done now. cant see why audi used the bomb setup though if function is equal.
    B3/B4 servo is bolt-on to B3/B4 chassis. If you want to fit a vac booster on your motor, jsut buy a RHD vac booster and it will bolt on. B4 hydro cars inc ABY coupe need to also use the servo bracket 8A0611945, but you should already have it on the B3, AFAIK it was used on all RHD cars up to 92.
    D3 does not just bolt on. D3 and other later models use a dual diaphragm booster so you get more line pressure for less pedal effort. you can also fit a larger master cylinder which gives a better pedal feel when you have larger caliper piston area.
    HTH, drop me a line if you like mate
  • A80Avant
    replied
    Only for left foot braking...!
  • GazzaG60
    replied
    edit
    replied
    B3/B4 pedal box is the same, so is the bulkhead mounting holes etc. The only thing plug & play on B3/B4 is B3/B4 stuff
