Something prtttt do before the engine start but its a quick...But that sound what u have, mine dont do that....I ve ordered one used ABS pump, so maybe when i have it, i give it to test like you. Can be tested only with pump? I see that you have whole system
Audi CQ20V ABS problem
Do you have battery voltage between pin 87 on big relay and pump chassis?
Yes, just connect charger or battery to the pump and short said 30 and 87.
It is the old system from my B3Q. Mine only worked for a few hundred meters, as it does not have any diagnostic capapility I built a new system from 1997 B5Q to find out which wheel sensor was faulty.
But the new system works fine with all the same sensors and abs rings. Will never know what was wrong with the old system1989 Audi 80 Quattro
Then your positive is missing. It is a thick red wire, goes to fusebox L30 terminal, and from there straight to battery.
Maybe it is disconnected from the fusebox?
L30 terminals. Unfused. Straight to battery positive.
ABS worked until i do renovation of subframes ...So everything new (brake lines, hoses, calipers, sensors) and other stuff. Ok i will check it
M2ki So i checked, there is ****** acces, but those cables are there...There u can see
edit : Now i have 12,7 voltage between battery negative and 87pin...But the ABS not give any sound with bridge pinsLast edited by Tom_; 30 June 2018, 17:09.Audi Coupe Quattro 2.3 20V
Then your pump motor is broken. You could try briding pin 87 and that red wire which goes to the pump motor just to be sure.
Also to be sure measure voltage between pin 87 and pump chassis/ground wire. I saw some older pic where you installed new yellow ground wire, but check it anyway.1989 Audi 80 Quattro
