Old diff prices start around 30€ in here, maybe it is similar there. Then easiest way would be to tell the seller, that you only want the actuator, and that he can keep the diff
Audi CQ20V ABS problem
Originally posted by Tom_ View PostI mean actuator, but i cant remember on name, so i wrote pump Thank you. I looke on net for buy one actuator..New is NLA. So only used one or from audi classic, but the price is little bit outPeter S
1990 ErsatzS2 - track toy
1991 Coupe Quattro
1991 Coupe Quattro
1995 S6 Sedan
1995 S6 Wagon
M2ki: i make a few topics in our country on forums and waiting for response Diff is always good to have another one
PeterS: Thank you, i ve already find some informations about Mercedes actuator P/N is 0008006975 and lot of people used it instead of VW or Audi one, with some modificationAudi Coupe Quattro 2.3 20V
Under the dashboard. 10A fuse on top and 76 written on it. These go bad also.
Take off the relay and bridge pin 2 and 6 to be sure it is not relays fault.
If you cant see the pin numbers on the socket, then its the thicker red and thicker black/blue stripe wire that needs to be connected.1989 Audi 80 Quattro
So i look at relay and fuse, and it looks fine, no problem...So i remove it, use your wire tip, and when i connect wire ABS turns off..when i remove wire ABS turns ON so i guess the relay is fine. But i noticed that ABS ground looks not so clean...Some pictures
Should be a bad abs ground doing my thing?
