I have bought a K26/27 turbo which im going to use on my car. But im looking at a Garret GT 3071 turbo. But im not sure what to do yet.........the turbo i have is flowprepped and ported so it will give full boost earlier than a regular K26/27 turbo. Is there anyone in here who uses a Garret GT 3071 turbo ?? When is full boost ?
Wanna switch from K26/27 to GT3071.......
You can say that again, got 2 of 1 and 1 of the other. I have never seen a turbo that you can blow into the compressor outlet (with you breath) and the wheel spins.Originally posted by Jamosearch for threads +400 pekka and RS2 Comp turbo.
the GT2871 and 3071 seem to be the turbo's of choice at the moment.Corey
01636 822288Comment
May i ask which one you are using on what car with what setup ?Originally posted by CoreyYou can say that again, got 2 of 1 and 1 of the other. I have never seen a turbo that you can blow into the compressor outlet (with you breath) and the wheel spins.
2003 VW Passat Highline 130 TDI wagon with ALL options.Comment
i tried to do that with my T04e ...... Not a chance
sigpicComment
Sure, it's no secret.Originally posted by S4-SledenMay i ask which one you are using on what car with what setup ?
GT3071 - 10v ur (mine) tubular exhaust manifold, 3" downpipe and exhaust (with seperate w/g vent and side exit tailpipe), 034 IIc ecu with coil per cylinder and lots of other stuff. Plus a bit of magic thrown in.
GT2871 - 10v ur see above
GT2871 - 20v (3B) 200 see above but ignore the IIc bit as we are sticking with Moronic for nowCorey
01636 822288Comment
One word of advice to anybody wanting to use the GT series of turbos make sure you use/order an oil restrictor
http://www.034motorsport.com/product...products_id=74
Don't find out the hard way.Corey
01636 822288Comment
Do you know the 3K part number of this turbo?Originally posted by S4-SledenI have bought a K26/27 turbo which im going to use on my car.
Should be on the blue plate secured to the side of the comp housingS2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!Comment
