Urgent! Need one of these fast!! Crank torsional vibration damper.on front of engine
  • Chris5044
    • Feb 2005
    • 1663
    Hey guys the plate on the front of the crank pulley has come away and hit my intercooler.
    Im in need of a new one or modified one asap.
    Also possibly a new or second hand intercooler for an aby. Or a modified one i dont mind.
    Any help or links would be appreciated, cars stuck here now.. ahhh!! Had travell far to do cambelt.
    pls help x
  • Chris5044
    • Feb 2005
    • 1663
    This gallery has 2 photos.
    • mllen89
      • Apr 2015
      • 63
      expensive part :S but here maybe they have a intercooler to. https://www.autewo.de/034105251m-aud...ngungsdaempfer
      • mllen89
        • Apr 2015
        • 63
        Artikelbezeichnung: 8A0145805B Audi S2 Coupe Typ 89/B4 20V Turbo ABY Ladeluftkühler Angebot besteht aus: 1 Stück Passend für Fahrzeughersteller:…
          Yeah not a cheap part to replace and its also part of the balancing for the bottom end i believe. Have a read about them on https://fluidampr.com/ and also worth having a look at https://www.s2forum.com/forum/member...i5#post2088391
            Engine vibration limits power and durability. Learn how to control it with proper damping to protect your build and maximize performance.
            • Chris5044
              • Feb 2005
              • 1663
              Ah yeh, the discovery was not pleasing, happy that I have learnt loads more. Thank you so much for your responses! Ill get onto this
                When you get a replacement, please can I buy your old one Chris
                • Chris5044
                  • Feb 2005
                  • 1663
                  Hey for sure buddy! could you be on the road to creating these? A great idea if you are and a forum saint! X
                  • Chris5044
                    • Feb 2005
                    • 1663
                    Been busy this week, lots of hurdles. Now the tensioner bolt sheared before it was even 20mn.. :/ gotta source 4 bolts now, as i want piece of mind now after that happening.
                    • Chris5044
                      • Feb 2005
                      • 1663
                      Anyone know the tensile strength of these bolts? Or are they standard bolts? It is for the cambelt change.
                      • Chris5044
                        • Feb 2005
                        • 1663
                        What I am trying to find out is are these standard bolts? Or specially strong because its part of the cambelt setup?
                          • Dec 2017
                          • 5987
                          Go 10.9 as it broke. It was probably 8.8 and overtightend previously.
                          By the way, I don't like to the look of the key on your bottom pulley. I can't see so well in your pic but if there is any doubt at all there I would change it for one of Chef's. If this fails it's a big job! Doing that as we speak.
                            • Dec 2017
                            • 5987
                            According to 7Zap bolt is N0102186
                            M6x25
                            Search on google shows OE was 10.9
                            • Chris5044
                              • Feb 2005
                              • 1663
                              Hey thank you buddy, yes i got a bilket one from the Chef himself! Ryback!!!
