Quick 'how to' replace fuel lines
This is a sticky topic.
  • Tom_
    replied
    Like a boss, Thank you Alex
    replied
    you need to flare the end of the fuel line:
    Then use some 8mm fuel hose:
    Then use a banjo with 8mm hose tail:
  • Tom_
    replied
    guys, how you figure it out this part?I have a lines, but have no idea,how solve this problem.Thank you
  • Trankelstein
    replied
    Fuellines
    Just got a delivery of 7,5 m Cu-Ni pipe and an assortment of wadeconnectors, including T-pieces because i´m planning to use a fuelpressuregauge.
    Have any of you thought about removing the fuelfilter from that horribly unattainable place and doing the feed pipe all the way up to the connector on top of the tank, and relocating the filter to a better place? I´m thinking of putting the filter somewhere closer to the engine?
  • Christophski
    replied
    Ahh cool thanks for that Jamo... Now I know what im looking for when I get under the car
    replied
    Yeah you can easily tell as only two on the lines go up into the bay the evap one runs towards the rhd drivers wing
  • Christophski
    replied
    At the back end of the car, can anyone tell me which of the three hoses running along under the car is the vapour/ breather line? Is it the one with the "Thingy ma jig" on it? (The one closest to the drivers side of the car)
  • Christophski
    replied
    Cheers Will.. Much appreciated for your knowledge
  • willg54
    replied
    I got a silverline flaring kit, only cost about £12 and did the job perfectly. There's a few vids on YouTube for how-tos.
    I'd buy a new fitting for the fuel filter too, makes a much neater job while you're at it! Etka will confirm but I think its m12. Oh, and some pipe clips!
    Sent from my HTC Desire using Tapatalk 2
  • Christophski
    replied
    Cheers Will. Right so I have the solid lines and Wade fixings paid for and hopefully on their way today (Thanks Nuvo) Just got to figure out how to flare the ends that go into the flexi lines and start to coat the "thingy ma Jig" as its referred to in this thread to try to loosen it off for the weekend.... This is one thing I will not be attacking with a blow torch to maker loosen!!! Hope I can tuck the back end of the car into the garage so I stay dry!!!
  • willg54
    replied
    Originally posted by Christophski
    Cool cheers Jamo. Also seeing as the pressure is not greatly high do the ends that go into the flexi hose need to be flared or can they be pushed on a reasonable amount and the petrol clamps put on to hold them secure enough?
    I'd flare the ends for the transition to flexi. I had one that wasn't and it leaked. Once it was flared and jubilee clip sat right up against it, nothing was going to leak out of it.
    For flexi lines on the filter end I use cotton braided fuel line but its quite well protected there. Not sure what else there is but not sure I'd trust its endurance directly underneath the car
  • re2500
    replied
    Ive got a couple of 90deg compression fittings in my engine bay, as the fuel lines on my CQ come up the bulkhead in a different place to the ABY. So when i fitted the ABY engine to the CQ i used a length of the engine bay lines from the ABY and fitted to the CQ lines using these 90deg compression fittings.
    I wish i knew that wade were the best as ive had a little trouble with one seeping and have had to replace it.
    TBH if i had read this guide before i would have been more comfortable with replacing all the lines tank-engine whilst i had the engine out, that would have been best!
    Great guide, cheers Alex. A job for the to do list
  • Christophski
    replied
    replied
    No you don't need to flare the ends they are held on by olives in the connector
  • Christophski
    replied
    Hey Will, what sort of stuff am I best getting? I think I have the Wade connectors sorted though but not a bad idea to have a back up plan...
    Also when using these wade connectors, does anyone know if you need to flare the ends of the pipes that the Wade connectors go on?
