One of those crank sensors is a position (flywheel teeth), the other is a reference (single flywheel pin). Check both.
This may be a really stupid question but are you sure the rotar arm timing isn't 180 degrees out? Make sure its sparking on the compression stroke and not the exhaust stroke! Open the oil filler cap and look at the exhaust camshaft on Cyl 1, you should be able to work out if the valve is open or not.
I would be inclined to change the entire dizzy for another you are sure works as hall sendors have a habbit of working when you test them, then failing when the engine rocks around on cranking.
Previous owners have a spectacular skill for lying and/or stupidity, so don't rule out timing or anything else on the basis of what he/she says.
Good luck and let us know what the problem was WHEN you find it!!!
Although im getting battery voltage at both
