Oil Pressure issues
  • A80Avant
    • 10873
    • Country: Greece
    #151
    i cleaned the contacts and cannot say i saw any difference
    in my case, my oil pressure @ 75C coolant temperature is 2.5bar on idle and at 81C is 1.5 to 1.8bar. Then if the car stays at 83-85C when the coolant fans kick in, it will go to 1.3bar and later on to even 1.1bar.
    all lifters are new on my engine, so i still believe its normal. I have >2bar from 1500rpm anyway
    i will be changing the sender once the break in of the engine is complete and put in a new filter and just wont worry about it.
    • max_s2
      • Mar 2006
      • 498
      • Country: Latvia
      #152
      IMHO you should also change cranks main bearings not only rod bearings. And I don't think that lifters could cause oil pressure dropdowns.
      • Avantus
        • Sep 2007
        • 941
        • Country: Belgium
        #153
        Just to make you all feel a bit better, went on a trip 2 weeks ago with amongst the cars a new 997.2 GT3.... oilpressure at warm idle = 1 bar
        • mcandmar
          • Apr 2004
          • 5118
          In relation to gauge accuracy i watched my 7A slowly drop from 2bar down to 1.5bar over a few years, then the sensor went faulty and wouldn't register anything below 1.5bar. Fitted a second hand sensor and it went back to 2bar. Basically take the pressure reading with a pinch of salt. Idle speed also effects your reading, a hundred rpms will make all the difference.
          If anyone is interested i opened one up to see how they work --> http://www.s2forum.com/forum/showthr...t=oil+pressure
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • A80Avant
            • 10873
            • Country: Greece
            #155
            How is the sender best accessible? Do you have to remove the radiator, or his the fan? Best from the top, or bottom?
            Had a look today and its not the easiest thing from the top
            sent using Android
            • Thuppu
              • 4115
              You need to have a really flexible hand.
              • mcandmar
                • Apr 2004
                • 5118
                I changed the lower sensor recently and pulled the radiator to do it. To get the fan off you need to lift the radiator to get at the bolts, so at that point i just dumped the coolant into a bucket and removed the radiator, made life much easier. It might be possible to change the upper sensor by lifting the PAS pump up and reaching in, a double joined arm would be needed.
                  From memory the only angle you can get a spanner on it is from the rear, would defo help with the rad out the way. I'm sure its possible without though, on an ABY / ADU with the slimline rad shroud.
                  • rs200
                    • May 2009
                    • 1398
                    • Home: Croatia
                    #159
                    I made a "special" tool for it..
                    my English are not so well , so I can't discribe you ..
                    tomorrow i will post a picture
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #160
                      what i am afraid of is the possibility of removing this one and then not being able to properly bolt the other one in to tighten it.
                      Looks like the aux water pump is in the way when trying to reach it from the back.
                      • max_s2
                        • Mar 2006
                        • 498
                        • Country: Latvia
                        #161
                        Today messured my ABY's oil pressure and it seems that I've everything tiptop with gauge readings.
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #162
                          how many kms do you have?
                          • Thuppu
                            • 4115
                            Max, quite high idle rpm's on warm engine..?
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              So what's the spanner size on the oil gauge sender?
                              Chef
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #165
                                that indeed. at 1100rpm i bet mine is near 1.8bar
                                my idle on the dash sits just below the 1000mark and vems reads it at between 910-940rpm when the engine is really hot.
