i cleaned the contacts and cannot say i saw any difference
in my case, my oil pressure @ 75C coolant temperature is 2.5bar on idle and at 81C is 1.5 to 1.8bar. Then if the car stays at 83-85C when the coolant fans kick in, it will go to 1.3bar and later on to even 1.1bar.
all lifters are new on my engine, so i still believe its normal. I have >2bar from 1500rpm anyway
i will be changing the sender once the break in of the engine is complete and put in a new filter and just wont worry about it.
