Compressor impeller seems more updated than the RS2 one (larger blades ect)
Volvo K24 turbo in audi application.
Also there are two versions of this cold side, the earlier years had a vband connection, later years have the style posted in this thread.
Here is a shot of the compressor wheel, this is comparing it to different volvo turbo
Here is some info about the Compressor wheel and the turbine wheel sizes:
Compressor Wheel:
O.D. – 62mm / inducer – 45.8mm / ETT (Extended Tip Technology)
Turbine Wheel:
O.D. – 59mm / exducer – 50mm / tip – 9mm / 5.4mm stub shaft dia.
TH:
6²cm area / set pressure – 7 bar @ 7mm lift
Quite interesting thread. Nice to get more easy "plug and play" upgrade options for I5 setups. Hope the performance would be competitive also. Waiting to see the dyno results.
Originally posted by Ruffiano View PostOh i was just going to mention, the nice thing about this type of swap is that you don't have to change your exhaust manifold, downpipe, or oil/water lines, it is a plug and play turbo like the rs2, however it is 15 years newer, readily available and a fraction of the cost... now lets hope that it is more powerful too!
If it works and you have the skills to DIY then for $150 I would hope so, however what is the price/availability of them in the UK?Current-2004 Impreza PPP wagon
Sold ABY-stock
Only saw one on ebay.co.uk
http://cgi.ebay.co.uk/VOLVO-S60-2-4-...item4aa401c07f
seems a bit steep. i know new from the dealer this turbo is around 950 usd.
So I wanted to update this even though I don't have numbers yet. I didn't get the car running before vegas so I wasn't able to get it tuned by Marc @efiexpress. As of this week I got it running. Hopefully this weekend I'll get everything buttoned up and get it back on the road for some street tuning.
This is part of the reason it didn't make it to Vegas:
to fit a filter for this turbo in the small chassis i had to get one of these "cobra head" adapter:
Still having a small trigger pin/vr sensor issue at sub 1500 RPM. I wish I had already been running VEMS before swapping the turbo, it would have made things simpler.
http://www.youtube.com/v/yjQvyO_tTfw
