1/3 of the price?? buying new too?
Volvo K24 turbo in audi application.
Originally posted by Rocco View Post1/3 of the price?? buying new too?
And no, not new, that's the thing - there's plenty of these available compared to K24-7200's.
I need to make some sort of a generic chipset for this turbo though. I don't think running RS2 chipsets will be very good with it.
Stock exhaust and DP are good enough for this power level as long as the cats are removed... there will be very little, if any gains by fitting a larger DP/exhaust.
The main gain will be saving weight.Last edited by prj; 4 April 2011, 08:02.
Back pressure and egt will be high stock exhaust I'd a restriction approaching 280 bhp, spool would be affected also 2.75 would be ok over 300
Are you lot also planning on running stock exhaust manifold as runners 1 and 5 are high on manifold and will also be affected at this power level
Originally posted by Jamo View PostBack pressure and egt will be high stock exhaust I'd a restriction approaching 280 bhp, spool would be affected also 2.75 would be ok over 300
I suggest measuring backpressure in the catless stock exhaust...
Exhaust manifold should be RS2 replica or better, this is obvious, due to the horrid design of the stock one.
Originally posted by Jamo View PostI've proven differently on a dyno also with separate cars re the exhaust, have to agree to disagree
If you actually look at the stock exhaust (catless!), then the cross-section is similar to a single 3".
Originally posted by terrybullwon View PostThats a new one
Need to sit down with the measurements.
