I grounded one to the I/m then the other to the bell housing on the transmission and it has worked in my application.
PIN SWAP i did it, RS4 B7 Coils inside¡
This is a sticky topic.
I need to get this pin swap done on my 3b to aan ecu and install the chip I bought off Vidar on here installed with the turbo off him...the thing is I'm ***** with electrics
anyone know someone local to Staffordshire that would be able to come and do the pin swap? I can pay and supply lots of bacon butties and tea haha
sigpicComment
You don't need to know much about electrics to do the job, as it's just moving wires from one location to another. What you DO need is someone who's able to perform the job in the footwell and doesn't suffer from a bad back. I'd suggest someone akin to a spider monkey with tourettes would be your best bet. They could easily get into the footwell and can amuse you ranting about how awful a job it is once started. I'd offer as I love bacon sarnies, but I've put on a few pounds and can't get into the footwell anymore. My tourette's has been much improved since completing this job on my 3B. Good luck finding a willing candidateI need to get this pin swap done on my 3b to aan ecu and install the chip I bought off Vidar on here installed with the turbo off him...the thing is I'm ***** with electrics
91 Modded 3B
14 A6 Avant Black EditionComment
Adapter harness for sale on S2forum - Audi S2 Owners on facebook, seller is Norbert Fizil
3B to AAN/ABY/ADU ECU conversion with TFSI coil harness. 250EUR shipped
Sold ABY-stockComment
Here i am 😉 if anybody need electronic/harness solution just write me. ☺Comment
does all this info still apply for a b2 chassis? im installind my 3b into my b2 sedan as we speak. i have 3b and aan harnesses. wondering if this is easier then installing the aan. ill be using the aan ecu regardless. what are peoples opinions here?Comment
AAN ECU would be better, but the AAN harness is very long into a B2 chassis and need a lot of electrical fabrication to connect to the relay panel, gauges, supply...etc etc. The inside connectors are alien for a B2.Comment
ill be using aan ecu with cop. but would be better to fit the 3b harness and do this pinout to the aan ecu? i think the 3b harness will fit the b2 better...Comment
Yes. Make the pinout swap and coil harness. The most of connector on 3B harness plug and play to B2.Comment
