PIN SWAP i did it, RS4 B7 Coils inside¡
This is a sticky topic.
  • araipilot
    • Nov 2012
    • 10
    I grounded one to the I/m then the other to the bell housing on the transmission and it has worked in my application.
    • paradox11235
      • Apr 2011
      • 15
      Does anyone have sources or part numbers for the motronic connector pins? Thanks
        If you are really in the US of A, check with Marc S. at EFI Express.
        • woodwoody
          • May 2015
          • 53
          I need to get this pin swap done on my 3b to aan ecu and install the chip I bought off Vidar on here installed with the turbo off him...the thing is I'm ***** with electrics anyone know someone local to Staffordshire that would be able to come and do the pin swap? I can pay and supply lots of bacon butties and tea haha
          • SteveH
            • 4460
            You don't need to know much about electrics to do the job, as it's just moving wires from one location to another. What you DO need is someone who's able to perform the job in the footwell and doesn't suffer from a bad back. I'd suggest someone akin to a spider monkey with tourettes would be your best bet. They could easily get into the footwell and can amuse you ranting about how awful a job it is once started. I'd offer as I love bacon sarnies, but I've put on a few pounds and can't get into the footwell anymore. My tourette's has been much improved since completing this job on my 3B. Good luck finding a willing candidate
            91 Modded 3B
            14 A6 Avant Black Edition
            • woodwoody
              • May 2015
              • 53
              Haha cheers ...and yep that's me fooked too haha no way I'll fit in there! And I won't even start on what's wrong with my back haha
              • andy10v
                • 5996
                Adapter harness for sale on S2forum - Audi S2 Owners on facebook, seller is Norbert Fizil
                3B to AAN/ABY/ADU ECU conversion with TFSI coil harness. 250EUR shipped
                Sold ABY-stock
                • woodwoody
                  • May 2015
                  • 53
                  Ah perfect!! So how do I get intouch with them!?
                    On here or on Facebook?
                    • Norbitron
                      • Oct 2012
                      • 72
                      • Country: Hungary
                      #130
                      Here i am 😉 if anybody need electronic/harness solution just write me. ☺
                      http://www.srsmotorsport.com
                      • booested4door
                        • Feb 2015
                        • 120
                        does all this info still apply for a b2 chassis? im installind my 3b into my b2 sedan as we speak. i have 3b and aan harnesses. wondering if this is easier then installing the aan. ill be using the aan ecu regardless. what are peoples opinions here?
                        • Norbitron
                          • Oct 2012
                          • 72
                          • Country: Hungary
                          #132
                          AAN ECU would be better, but the AAN harness is very long into a B2 chassis and need a lot of electrical fabrication to connect to the relay panel, gauges, supply...etc etc. The inside connectors are alien for a B2.
                          • booested4door
                            • Feb 2015
                            • 120
                            ill be using aan ecu with cop. but would be better to fit the 3b harness and do this pinout to the aan ecu? i think the 3b harness will fit the b2 better...
                            • Norbitron
                              • Oct 2012
                              • 72
                              • Country: Hungary
                              #134
                              Yes. Make the pinout swap and coil harness. The most of connector on 3B harness plug and play to B2.
                              • booested4door
                                • Feb 2015
                                • 120
                                thats what i want to hear. im on it!!
