Big fuel leak out of injector 5
EV14 Fuel adaptor differences
This is a sticky topic.
I don't see how the seals can go loose if the fuelrail is fit and there is not too much play on the injectors?
BMW 740iA e38 - ProjectComment
^^ info Jamo!
I was just going to run with 034 spacers and try to bend the injector clip a little to attach the spacer to the fuel rail. And also drill out the holes slightly to drop the fuel rail a couple of mm. However, if this is still prone to leaking I'm either going to rethink that.AUDI - saving Dad's from minivans since 1994
I just run them without clips, but change all the O-Rings for the AAN ones, which are thicker, and they are fine.
They are so tight that it's hard to remove them by hand, never mind them coming loose...Comment
Not on the latest batch, no...
With the spacer it is better of course. Especially with spacer and AAN O-Rings.Comment
i see, thats a good point, as the problem would only occur if the injectors move out of position.
so either:
1) secure them at the top
2) secure them at the bottom
1: extenders that have option of clipping on the injector and the rail, thus the injector acts as one, and once clipped on the fuel rail, will not move
2: extenders free and apposed by the fuel rail, while secured at the bottom by a spacer that will not allow them to move further down.
I think we have found the solutions for these small injectors!Comment
0-200km/h 9sec
