Stock, stroker or ghetto capacity increase? ( supra 7m gte pistons bmw rods )
This is a sticky topic.
  • diesel des
    • 3896
    #136
    All parts are from 20vt other than TDI block and crank.
    Sent from my Moto G (5) using Tapatalk
    • Tom_
      • Oct 2007
      • 1301
      • Country: Czech Republic
      #137
      Will i fit directly Bosch EV6 750cc injectors or 980cc to 3B fuel rail and 3B intake manifold? What about using a AAN pistons and little bit sliced to get lower CR and FCP 155mm rods ?
      Audi Coupe Quattro 2.3 20V
      • diesel des
        • 3896
        #138
        Skimmed aan pistons in a stroker will give a very high compression or very weak piston if you took enough material off to get the correct compression.
        You can fit whatever injector you want as long as it's the correct length and connector for the electrics. I use ev14 1200 cc in my urq and 630cc Siemens in the urs4.
        • Tom_
          • Oct 2007
          • 1301
          #139
          Its true, i want to save some money, because get AAN pistons will be more cheaper than a new FCP ones. But i guess you are right Whats the duty of your injectors? I wan to use EMU ecu, but i am dont know right now, whats the correct lenght and connector. Its possible to see some combos of injectors or its just try/fail procedure?Thanks anyway
          • diesel des
            • 3896
            #140
            At 450bhp on my urs4 I'm at about 75% duty
            • Tom_
              • Oct 2007
              • 1301
              #141
              Those 1200cc ? So if i used a 980cc on the sam power range...it will be closing 90%
              • diesel des
                • 3896
                #142
                No that was on the 630cc in the urs4 at 75% with 450 hp. The urq will make 650 bhp and the 1200 cc injector was for e85
                • Tom_
                  • Oct 2007
                  • 1301
                  #143
                  Any differences between AAT vs AEL ? Or just the same modifications on the blocks ? TY
                  • AndyP
                    • 6049
                    No difference, you have to do same mods to both.
                    • Tom_
                      • Oct 2007
                      • 1301
                      #145
                      And what about quality and strength of block? I can choose between AAT and AEL. Price is almost the same. Thanks Andy
                      • ADP
                        • Mar 2011
                        • 200
                        • Home: Bulgaria
                        #146
                        Block from AAT and AEL are more stronger than AAN "joke" block ! So the stroker is expensive way to give more power! Be very carefull when choosing the block,common problems are bended krank tunel,and slack main caps on N2 and N4,otherwise you will have a problem with oil pressure and bearings! Need more precised machine work on block and cylinder head. Both AAT and AEL DONT have e valve fited inside of the oil galery,this valve is importnat for life of the engine and hydros! Crankshaft is forged and more stronger than AAN,and it weight - 2,1 kg more.Same with block-10 kg more,as per my scale.After 1996 Audi use better spherografite graycast iron,more stiffer and stronger compare to other old blocks.If you can find TDI block after 1996 is better.Do not make a holle on the back side of the block for water passage,use the metal tap on head-better water cooling for cylinderhead aswell.As per my opinion is far better to use 2.7 biturbo engine instead the 2.5 stroker wit 236mm block!Less expensive way,and more power!
                        • Tom_
                          • Oct 2007
                          • 1301
                          #147
                          ADP which valve you mean? That one where is oil pressure sensor? I like sound of 5 cylinder and its easier on MOT with 5cylinder stroker engine, then a 2.7 V6 engine
                          • ADP
                            • Mar 2011
                            • 200
                            • Home: Bulgaria
                            #148
                            This is non-return oil valve! very impothant valve,when you shut off engine hot!!!!!When you make a stroker,both AAT and AEL bloks dont have this valve!!!!!!!Be carefull.On diesel bloks this valve are in cylinder head.
                            • ADP
                              • Mar 2011
                              • 200
                              • Home: Bulgaria
                              #149
                              personaly i DONT like I5 engine,very old architecture ,not eficient ,and very worst cylinder head and combustion chamber!
                              VW R32 and New 7k I5 cylinder engines are different story!!!
                              • Tom_
                                • Oct 2007
                                • 1301
                                #150
                                Yes, but if you put those engines in 89ยด year car, you will never pass a MOT and then you have big troubles with insurance,etc..
