Black Smoke and Lumpy then Gone !
    Originally posted by andy10v
    3B ecu does use the mfts, faulty mfts/plug can make the ecu limit boost.
    Ian
    You can get a new plug/pins/wire from the dealer for not too much money.
    Not for the coolant temperature reading it doesnt to which I was referring
    The coolant temp value you see in vagcom comes from the sensor in the head but he has changed this already
    • ian4455
      • Nov 2010
      • 787
      To sum this up - over Fuelling is the result of a problem on my car. Engine is always ok from cold but as it warms up at some point it starts to splutter. Let it idle after it does this the boost gauge instead of reading -6 its at -2 with the extra fuel going in. I leave the car running at idle like this for a minute and it suddenly stops doing this.
      • salad.dodger
        • May 2011
        • 83
        I know my 100 turbo MC2 engine is different but it does this on start up, lumpy with black smoke until rev'd to 3000 rpm
        I was told lamda probe could be at fault????
        • ian4455
          • Nov 2010
          • 787
          Just done the blink code test, 2341 02 sensor exceeded... expect that if it was overfuelling.
            Have you tried clearing the Adaption tables in the ecu?
              That is the code that people get when they have a leak in the hoses between the MAF outlet and the throttle body. Have you checked for boost leaks and in particular the condition of the MAF to turbo hose. Those have been failing due to age, etc. more often recently. That would be the 3B equivalent of this AAN black rubber hose in the bottom right of this diagram:
              • ian4455
                • Nov 2010
                • 787
                I'll check the hose tomorrow, how do you clear the adaption tables in the ECU ?
                  Pulll the "motor" fuses in the fuse box for a few minutes.
                  The low vacuum reading certainly points to a boost leak.
                    Previously I suggested that according to Paul N's diagrams (pg.43/57), on the row with the No. 23 through 32 fuse holders, the No. 23, 26 and 30 holder positions are empty, with No. 24 = the ISV, WGFV and Evap Control fuse, No. 25 the O2 sensor fuse, No. 27 = ECU constant 12v, No. 28 = fuel injectors and MAF and No. 32 = coils (reference: Paul's wiring pdf, Pg. 40/57)
                    As a result, I think you mean Fuse 27 (under the Orange "Motor/Moteur" cover):
                      Easiest to just pull the 2 out as a pair complete with the orange cover
                        Agree. I just was pointing to fuse 27 in case Ian's fuse box was missing the orange "Motor/Moteur" cover.
                        • Jonas_R
                          • 3781
                          • Country: Denmark
                          #27
                          Have you tried changing the lambda probe?
                          Sleeper S2 Avant +450
                          A6 Avant 2.7t Stage 3
                          Audi S2 Coupe RS2'ed
                          • ian4455
                            • Nov 2010
                            • 787
                            Prior to upgraded my 3b the car was running fine, after fitting the RS2 turbo and running the car for the first time it leaked a considerable amount of oil from the hot side into the exhaust. Turbo's sorted now but wondering if all that oil has broken the Lambda sensor ??
                            • 220bhp
                              • 2578
                              • Home: United Kingdom
                              #29
                              What chips are you running this car on,or who mapped it.
                              • ian4455
                                • Nov 2010
                                • 787
                                Using a fault code reader i get a 0537 fault code after it starts running lumpy.
