Coil Pack Wiring Harness - OE
This is a sticky topic.
  • Rusty
    • 18953
    I've just done the frankly terrifying job of tidying up the wiring for my coil packs - te wiring under the cover. All the wires are brittle and cracked to hell so it's no wonder tat the car wasn't happy. I've heat shrink wrapped all the wires in an attempt to get it at least insulated. What a nightmare that was, taking apart the plugs etc.
    Anyway, anyone know if you can get a replacement wiring loom or any of the components to make one? Another fun job for another day...
  • Audi Parts Guru
    • 1317
    Sadly no loom available. Plenty of heat shrink and concentration is about the best you can do
    • Rusty
      • 18953
      How rubbish... A little project maybe.
      • willg54
        • Jun 2009
        • 2055
        you can buy the connectors im sure but you'll need the proper crimping tools. not sure what its like at the coil end though. I'll have to take a look this weekend...i want to do it on mine.
        Might be a case of splicing some new wire on to the coils and heat shrinking.
        If you missed an older post of mine...you can get free raychem heatshrink from the tyco electronics website, you can order free samples.
          Ignition Coil and POS info
          Originally posted by Rusty
          ...Anyway, anyone know if you can get a replacement wiring loom or any of the components to make one? Another fun job for another day...
          You can buy the connectors and pigtail wires (pins and a short lead) from Audi (plugs and boots, items 23, 24 and 25 below). You can also buy junior timer plugs and bare pins (no wires) from various after market suppliers. What you can NOT buy is a replacement harness since none exists. (BTW, replacement coils come with a considerable length of wire already attached)
          • twenty valve
            • Oct 2010
            • 630
            suprising im the first to ask why dont you use coils from a 1.8t/2.5tfsi etc etc
            you then have a brand new loom, you can remove the amplifiers and the coils are cheap and easy to replace
            • Rusty
              • 18953
              I've not spent any money so far, just trying to repair what I have... Spent enough for the mo!!!
              • saltinot
                • May 2004
                • 1946
                I was just chatting yesterday with the parts folks at my local dealer about this. Like Dave said, you can source the connectors with a pigtail from them. You can also source the connectors by themselves. I have new Beru coil packs that are supplied with a length of wire already and I don't want a solder connection in the middle where I have pieced two lengths together. The just need to be cut to length and then crimp on the connector.
                SO, I have yet to determine which connector is the right one. There are several in the Audi/VW electrical catalog that look to be a close match. Anyone know?
                • Rusty
                  • 18953
                  So how much wiring to they come with? OE is fairly lengthy, maybe 750mm for coil 1. Just need S2avant to advise on VAG prices...
                    OE Ignition Coil Connector PNs
                    Originally posted by saltinot
                    ....SO, I have yet to determine which connector is the right one. There are several in the Audi/VW electrical catalog that look to be a close match. Anyone know?
                    The coil connectors are as follows (I think):
                    1. The three pin female connector housing to connect the coils to the POSs (which have integral male pins on both ends) is Audi 433906233 (AMP 929552) (item 23 below)
                    2. The three pin MALE connector housings for the primary power from the two white harness connectors to the coils don't show a Audi PN on the white male version (no jokes please) other than "DM4 Austria" and "510011-1500". (These can be scrounged from 3 pin VW Golf III O2 sensors in a pinch). However, as it turns out, the 3 pin male for the female 433906233 is 443906247 (Item 24 below) which should work (other than the colour) (Note the "21" and "22" pairing in the second diagram). (I have new white ones in my hand but no invoice but I bought them from a VAG parts dealer (about 5 years ago))
                    • saltinot
                      • May 2004
                      • 1946
                      Did I say connector?? I meant terminal.....I'm thinking it's one of the ones on the bottom row. 42? I guess I'll get my calipers out and get to measuring one. I'd order one if I could. Unfortunately they come on in boxes of 25.
                      • Rusty
                        • 18953
                        Be good to get a list of part numbers together for sure
                        • willg54
                          • Jun 2009
                          • 2055
                          Dont every solder wires together like that...its goes brittle and will break with vibration.
                          Get some crimped splices and seal with a bit of small 1/8th heat shrink after. proper job! Any good loom will never have solder on it.
                          If you do want a quick fix, i trialed some heat shrink with the solder already inside. you just heat it up, it shrinks and seals it. It seemed pretty good to me but would always prefer a proper crimp.
                          • Rusty
                            • 18953
                            He said he didn't want a solder connection...
                            • willg54
                              • Jun 2009
                              • 2055
                              I was just saying never solder wires together...much better alternatives
                              Sent from my HTC Desire using Tapatalk
