Coil Pack Wiring Harness - OE
This is a sticky topic.
  • Michael S2
    • Dec 2011
    • 1378
    Finally got my loom made with the new coil packs. Car is absolutely flying with no misfire
    Just to help anyone else looking for the parts to do this job
    I ended up replacing the 2 white connectors with these:
    http://3waycomponents.co.uk/Automoti...-Kit-With-Boot
    as i couldn't source the terminal pins audi used in the white connectors.
    For the brown and black connectors i used these terminal:
    TE Connectivity Junior Power Timer Crimp Terminal, Female, 1mm² to 2.5mm², Tin Plating
    Stock no.: 718-1317
    Got these from RS components online these fit the original connectors.
    Then you also need some heat resistant sleeving for the wires. I used Vidaflex SD350 purchased on ebay. Think 6mm is what i used mostly but if you wanted it to look like a real pro job then you'd need varying sizes.
    Anyway an easy enough job but time consuming...requires a lot of patience. Worth the effort and expense
    1995 Audi S2 Avant
