Coilpacks on the 3B
  • Rusty
    • 18953
    I know, I was deflecting the blame You've not seen the episode of the Simpsons where Bart is 'the I didn't do it kid' then?
      I have 2 boys amigo, I know the plot off by heart
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #63
        Amigo? Do you speak spanish then?
          Originally posted by yodasfro
          I wonder if the ebay kit would work on a 200 20v anyone know? Looks pretty simple really, I thought the conversion was much more involved swapping a lot of pins at the ecu connector and such? I'm sure one could make up their own harnesses for a lot less.
          Austin: If you scroll down in the original ebay.de post, you will find links to two pdfs regarding the installation and wiring for that "kit". One or both of them documents the pins that need to be moved in the 3B harness T55 female connector to match up with the AAN (or ABY/ADU) ECU T55 male connector. (It isn't as plug and play as it first looks).
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #65
            Be careful,the pdf documents from the seller has mistakes,the way to do it is following Paul's nugent pdf. It is explained in the pin swap thread ,it is sticked in the engine/turbo section.
              Si habla Espanol com Bart Simpson! Bocadillo, tapas, cafe con leche, patatas fritas, huevos rancheros! No promlemo, hasta la vista baby!
              • yodasfro
                • Apr 2006
                • 129
                Yeah I already did that the instructions seem vague to say the least.
                Austin
                1992 urs4 1991 200 20v avant 1990 90q 20v
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #68
                  Originally posted by driftin jo
                  A thread is like a garden, they need constant attention, if you leave them for a while you will come back to find weeds everywhere and looking nothing like you left it.
                  Oops, that's another weed in the garden.
                  SS
                  • tajgreidotu
                    • May 2008
                    • 324
                    • Country: Spain
                    #69
                    Hi all!
                    Im almost completing my conversion from 3B to AAN, including AAN Ecu, AAN engine harness, AAN coilpacks.......
                    My question is, do I have to change the 3B valve cover to AAN-ABY-RS2 or can I use 7a one??OIf course, with stock AAN coils
                    If I can help with something.....
                      Originally posted by tajgreidotu
                      Hi all! Im almost completing my conversion from 3B to AAN, including AAN Ecu, AAN engine harness, AAN coilpacks.......My question is, do I have to change the 3B valve cover to AAN-ABY-RS2 or can I use 7a one??OIf course, with stock AAN coils. If I can help with something.....
                      Someone will correct me (if I am wrong) but if you are running a 3B style intake manifold with the throttle body at flywheel end of the engine AND OE AAN coils, you will need an ABY or ADU cam cover. If you are running the AAN intake (with the throttle body near the front of the engine), AND OE AAN coils, then you will need an AAN cam cover (but an ABY or ADU one probably works too).
                      • tajgreidotu
                        • May 2008
                        • 324
                        • Country: Spain
                        #71
                        Hi Urs4boy
                        My plans are to run Aan IM and AAN oem coils....so complete aan system into a 3b
                        • driftin jo
                          • Sep 2007
                          • 2222
                          I would use an AAN/ABY cam cover if you are going to use OEM coils.
                          I can't say that you can't make it work with a 3B as I have not tried , but
                          I have to say even if you could make it work with the 3B it would be better with
                          the AAN/ABY cover.
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            #73
                            Originally posted by SteveH
                            Rocco, how hard did you find it to do this on a 3B?
                            Getting hold of the ABY Motronic and harness from e-Bay looks simple, what about the pin swap and wiring?
                            You don't need the aby harness just the ecu. But I would get the aan ecu since they normally sell for less.
                            You need a tool so you can undo the pins in the ecu plug. I think you can do it in a day maybe that is with mounting and wiring of new coils, pin swap, adding the 5 trigger wires for the coils. Also need some time for beer.
                            Sleeper S2 Avant +450
                            A6 Avant 2.7t Stage 3
                            Audi S2 Coupe RS2'ed
                            • Rusty
                              • 18953
                              + ECU plug open heart surgery =
                              • Jonas_R
                                • 3781
                                • Country: Denmark
                                #75
                                You just need some labels, then it can't go wrong. Even with a couple of beers
