Which rocker cover with TFSI coils?
    Currently ABY but 7A is tempting, although I'll have to rework the breather... Who has done what?
  • Christophski
    • 3632
    I have kept my ABY one and will be doing something coil cover wise at some point....
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      aby or AAN is a perfect fit
      but now i drive without the coil cover for cooling
      the picture is from my car
      TWINCHARGED power,zero lag
      AEM W/M injection
      • Colesy
        • Feb 2009
        • 2980
        I have 7a with the plug holes bored out, a 3b breather pipe to replace the through cover pipe, hole drilled for breather pipe. Cover was £50, machining worked out at £60. Harness from Alex/Error and new coils. Haven't got it running yet but won't be long. With the rubber boots trimmed down on the coils they sit down securely on the plugs and look pretty good.
        I can get some better pictures if you'd like?
        • Rikki Kitto
          • Feb 2010
          • 6276
          I got this off fleabay but need to find some spacer so it doesn't sit on top of the coils although I don't think it matters
          • Jonas_R
            • 3781
            • Country: Denmark
            Was the cooling not sufficient with the holes you made?
            I was planning to do the same thing myself.
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
            • Henkjan
              • 1705
              how about no cover but only Aaron's carbon eye-candy mounted so that there is ½" space left open?
              • Laaf
                • Oct 2010
                • 275
                This is a 7A cover with plug holes bored out, don't remember the diameter though. A friend did it for me. Added a -AN10 outlet for the breather in the rear, upper side of the cover. I pulled the toothed gear of the camshaft to spare the breather from it splashing oil.
                  I'll give you my standard answer on this:
                  Putting a cover, any cover, over the 1.8t/2.0t/TFSI coilpacks will hasten their death due to heat build up.
                  Better letting them run wild and free:
                  (from my injector insert replacement post: http://forums.quattroworld.com/s4s6/msgs/266127.phtml)
                    There are two things that contribute to early death of those transistorised coils IMHO -
                    1. excess heat generated by longer dwell time than required to run them up to target primary current
                    2. heat soak exaggerated by placement of the metal cover i.e no air flow
                    I am looking into this more and more (time permitting).
                      There are two things that contribute to early death of those transistorised coils IMHO - 1. excess heat generated by longer dwell time than required to run them up to target primary current 2. heat soak exaggerated by placement of the metal cover i.e no air flow).
                      The dwell time is an issue but typically only on a 20VT that is being tracked (high RPM for sustained periods). The 4 ms stock dwell time in that situation is too long; prj (dmitri) has already suggested 2 ms is enough for these newer generation coil packs. He modifies the chip sets accordingly (if he knows which coils are going to be used).
                        Yeah yeah - but do u really think everyone who has fitted a TFSI upgrade has asked dmitri for a chip tweak ???
                          Info I have is that dwell is mapped only against battery voltage on the 20VT - it's not like the dwell time is wrong only at high rpm but the coils need more thermal headroom at high load / rpm so that's where you exacerbate the heat issue caused by excess dwell.
                            No. I didn't say that. However, *IF* dmitri knows that you are running TFSI coil packs when he sets up the upgraded chip set for you (think Stage 1, Stage 1+, Stage 3, etc) then he will adjust the dwell accordingly.
                              Mine's stage 4.32.256.
                              Think I'll look in to modifying an ABY/AAN/ADU effort for now.
