S6 timing
  • HMS-S6
    • Jan 2010
    • 1164
    #166
    Whatever it is curiously goes away after a gear change or a period of over run. Tried it again today and it kept doing it; gutless in 3rd when the revs were allowed to rise from below 3,000 change to 4th and it pulls just as it should.
      Originally posted by HMS-S6
      Tomorrow I'm going to check the fuel FLOW as so far all I've checked is the pressure foolishly!
      Testing fuel flow on an UrS4/S6 (could be adapted to an S2 or RS2):
      • HMS-S6
        • Jan 2010
        • 1164
        #168
        Cheers for that Dave!! Does my symptoms soulf like it could be a basic fueling issue? It had a new Audi pump fitted two years ago and new metal pipes under the car but there are a few rubber ones on the tank?
        • twoqu
          • Sep 2003
          • 3103
          #169
          There does appear to be an overrun fuel cut off but I am not sure how it functions as its Motronic trickery!
          You are also going from high vacuum to boost. Of course that leaves the PCV valves which route either back into the inlet manifold or the turbo depending on vac/boost. So no harm in checking the function of those. The large black one has an internal diaphram that tears.
            Did you check the wee PCV valve I mentioned in an earlier post?
            • UrS6 - IamS6
              • Nov 2014
              • 148
              • Home: Ireland Current: Western Sahara
              #171
              I presume you are not using the metal 034 little valve in the PCV system ?
              A new oem one is better. Just mentioned so that everything is checked / covered.
              Are there any rubber hoses that might be collasping / acting up in the fuel system.
              You must be getting closer at this stage.
              • HMS-S6
                • Jan 2010
                • 1164
                #172
                Hi all, thanks for the breather ideas but both the small valve under the manifold and the large black one are both under 6 months old and genuine Audi. Plus to further eliminate the large one, I drove the car with it disconnected and the hole in the MAF hose plugged up.
                • HMS-S6
                  • Jan 2010
                  • 1164
                  #173
                  Is there a channel on vag-com to show what the MAF is reading or any other way to see this? I'm sure it's down to fuel supply or Air measuring. The spark surely has been rules out by the COP conversion? And I've checked the valve timing a million times now. Exhause is clear and been swapped 3 times now. Car is boost leak free and the pressure is correct and perfectly steady.
                    S6 timing
                    Is the MAF hose soft? I'm not sure what it's like on the s6 but on my coupe the original hose had gone floppy with the oil and was collapsing on boost and starving the engine of air. I think it made the boost drop too though, it's a long time ago.
                    • UrS6 - IamS6
                      • Nov 2014
                      • 148
                      #175
                      I presume you may have already done it, I read the full thread a while ago, but it can do not harm to do it again, is to spray the various electrical connections with electrical contact cleaner, on the MAF and TPS sensors in particular.
                      • HMS-S6
                        • Jan 2010
                        • 1164
                        #176
                        Just checked fuel FLOW and with 12.2v for 15 seconds it gave 850cc of shells finest so seems ok??
                        • twoqu
                          • Sep 2003
                          • 3103
                          #177
                          Group 000 2nd value is the Maf value in Vag com.
                          • HMS-S6
                            • Jan 2010
                            • 1164
                            #178
                            What values would you expect to see at 1.2 bar at 3500 RPM?
                            • twoqu
                              • Sep 2003
                              • 3103
                              #179
                              The ABY value would be the nearest AAN.
                              That all the info we have I think!
                              • HMS-S6
                                • Jan 2010
                                • 1164
                                #180
                                Right! New FPR didn't sort it either!
