S6 timing
  • HMS-S6
    • Jan 2010
    • 1164
    #46
    Yes. Absolutely was a private road!
    Days like yesterday make me feel like giving up on it.
    • HMS-S6
      • Jan 2010
      • 1164
      #47
      When pressure testing the whole system, is it normal for a small amount to sneak past the rings?
        Yes
        • HMS-S6
          • Jan 2010
          • 1164
          #49
          Was just thinking of another boost leak that could show itself only when running?
            Maf connector thread
            Did you check the DV for leaky diaphragm?
            • HMS-S6
              • Jan 2010
              • 1164
              #51
              Ok. I'll give that a go too. If all else fails I can see a use for it on November the 5th. Lol
              • prj
                • Mar 2010
                • 6308
                Not really. Or well, it depends how you put it.
                In a tight car you can put say 1 bar in, come back after a minute or so and there will still be 0.5 bar or so in the intake.
                Your AFR going from 10.9 to 12.5 means you fixed some massive boost leaks. It takes a lot of leakage to get that much more fuel. Essentially 20% of the air was leaking before.
                If it's running 1.4 bar with 12.5-13 afr that means it's a bit lean really and if you hammer it, it gets very hot, starts knocking and then the ECU will pull timing.
                I don't want to step on anyone's toes, but are you sure the map is good? Maybe try a different ECU with a different map on it and see if that cures your issue?
                • 220bhp
                  • 2578
                  • Home: United Kingdom
                  #53
                  I had the red hot turbo issue on my 3b coupe with stock turbo set up. It turned out to be the TPS. changed it for a second hand one and it cured the issue.
                  Your exhaust symptoms could be caused buy vacuum leaks . I know you have done a boost leak test, but have you checked for vacuum leaks.
                  The other possibility is that if its been running badly for a while is that you may have killed the lambda. I hope you find the problem soon.
                  • HMS-S6
                    • Jan 2010
                    • 1164
                    #54
                    Hi, thanks for responding. I'm not stupid enough to realise I'm wrong. I spent all afternoon fixing leaks all over it!
                    And yes, the same thought crossed my mind, I ran this ecu on another car and it seemed fine but I'm still going to use its stock ecu first today to see how it is.
                      Presuming you disconnected the breather system at the MAF hose when pressure testing, you could still have a leak in one of the PCV pipes, this would allow extra air to be drawn in after the MAF.
                      • HMS-S6
                        • Jan 2010
                        • 1164
                        #56
                        Yes I pressured the system from turbo onwards. Not through the MAF hose.
                        • HMS-S6
                          • Jan 2010
                          • 1164
                          #57
                          Is 51 degrees too much for intake temp?
                          • HMS-S6
                            • Jan 2010
                            • 1164
                            #58
                            After running it from cold today it still runs exactly the same as with all the leaks. It appears in back to square one.
                              #59
                              50 plus is very high - especially for this time of year !
                              • HMS-S6
                                • Jan 2010
                                • 1164
                                #60
                                Powerwise its really struggling again today! It was 40 after one WOT run!
