You can't see knock sensors on any "breakout thingy".
Looking at the knock sensor signal does not tell you if the ECU is doing something with it or not. There is a lot more to knock monitoring - that is why the ECU needs the hall sensor for example etc.
Need proper knock retard logging to make any conclusions whether the ECU is pulling timing back or not. And for that you need either some arhaic factory diagnostics tool or custom code in the ECU.
