Those who run LPG converted 2.2's
  • hunker7
    replied
    Originally posted by diesel des
    That's good enough fuel economy. In what way is it sluggish? On petrol and gas?
    I expect it to go down by couple mpg, hopefully. It's sluggish on both.
  • diesel des
    replied
  • hunker7
    replied
    Got 20mpg on 186 mile drive. That's a bit more than expected, but she's not calibrated properly, and seems to be sluggish too so considering that it's not that bad.
  • hunker7
    replied
    Mine isn't 450hp
  • diesel des
    replied
    Yea I have got 23 a few times but that's not opening the taps and staying below 70...
  • hunker7
    replied
    I get about 27 on a long run, so will be expecting 24, but she isn't running correctly so maybe less.
  • diesel des
    replied
    I loose about 10% on gas. So about 20 mpg on petrol and 17 or 18 on gas average.
    I get much more on a long run but I can't stay out of booooost...
  • hunker7
    replied
    I'll give it a shot. Was meaning to ask, how does your gas consumption compare to running on unleaded?
  • diesel des
    replied
    Try both the aeb ones.
  • hunker7
    replied
    Reserve, AEB820 and AEB1050. Trip computer?
  • diesel des
    replied
    What options were there? I think there are options for different ohm scales and from memory you could set at which value which light came on.
    The gauges is only a guide and I use the trip computer to give me a better idea.
  • hunker7
    replied
    In software I used Reserve as level sensor and can only change what colour LED comes on when it switches to lpg.
  • diesel des
    replied
    Think there is a way of calibrating that. Also can try different sender types in the config.
  • hunker7
    replied
    Just noticed level sensor doesn't show full tank? Only first green light comes on?
  • hunker7
    replied
    As I said, he only said it about this specific ECU. He doesn't know what car I drive or anything. I will ask him more when I go down I will get wideband as soon as I got some spare moneys, and then have another go at adjusting it.
    Honestly, I'm glad he said it can't be done/he cannot do it, rather than charge me for nothing.
