Those who run LPG converted 2.2's
  • diesel des
    replied
    So you need to enrich the gas at 4 ms quite a bit.
  • hunker7
    replied
    Did 3 reading for each speed/gear
  • hunker7
    replied
    Works on voltage. It should be linear so I'll try empty tank voltage and full tank voltage (easier ) and if that doesn't work then I'll hook up multimeter on one of the trips or laptop that'll happen when it's all calibrated correctly though
  • diesel des
    replied
    You could measure the resistance as you drive. So use your odometer to note resistance as the miles goes on and the tank empties. Then calibrate the ecu to suit.
  • hunker7
    replied
    Level sensor isn't working still, I have to calibrate it, but how do I know voltage does sensor read at each quarter tank? Do I just record full tank, then empty tank and decide by 4?
  • hunker7
    replied
    I'll get it done tomorrow
  • diesel des
    replied
    Doh
  • hunker7
    replied
    Went out to take measurement and took petrol on petrol but didn't record petrol on gas, instead got petrol and gas
  • hunker7
    replied
    OK I'll get that done tomorrow. On unleaded it runs much smoother, still trying to find out what is causing sluggishness
  • diesel des
    replied
    Yep need to get the higher ms times trimmed in too.
    Even stock 25mpg seems good.
  • hunker7
    replied
    Mine is only stage 1 mapped. I am going for a drive tomorrow night, so 4th 5th 6th gear at 60 70 80mph should do?
  • diesel des
    replied
    I have never got over 25mpg on petrol. But maybe it will improve once all the settings are dialed in.
  • hunker7
    replied
    That's 30% higher consumption in comparison to unleaded, which I think is too much. I get 27mpg on unleaded with about 3/4 of tank on motorway and 1/4 around town.
  • diesel des
    replied
    19mpg still sounds ok to me.
  • hunker7
    replied
    I did 197 miles on 47 liters, which works out as 19 mpg. I'm expecting something in the region of 24mpg. I did 150 mile drive and got a similar mpg last week.
