Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #256
    I get about 27 on a long run, so will be expecting 24, but she isn't running correctly so maybe less.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • diesel des
      • 3896
      #257
      Yea I have got 23 a few times but that's not opening the taps and staying below 70...
      • hunker7
        • Mar 2014
        • 3487
        #258
        Mine isn't 450hp
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          #259
          Got 20mpg on 186 mile drive. That's a bit more than expected, but she's not calibrated properly, and seems to be sluggish too so considering that it's not that bad.
          '93 Audi UrS4 Avant
          • diesel des
            • 3896
            #260
            That's good enough fuel economy. In what way is it sluggish? On petrol and gas?
            • hunker7
              • Mar 2014
              • 3487
              #261
              I expect it to go down by couple mpg, hopefully. It's sluggish on both.
              '93 Audi UrS4 Avant
              • hunker7
                • Mar 2014
                • 3487
                #262
                Thinking of having another go at calibration. Currently petrol ms goes down (3.1 to 2.1) when switching to gas, so I should decrease ms on petrol injectors (2nd and 3rd point on modelling graph)?
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #263
                  You need to adjust the point on the graph nearest 2 or 3 mg. You can also move the points left and right to shape the graph. I would put a point right arround 3 ms so it adjusts idle
                  • hunker7
                    • Mar 2014
                    • 3487
                    #264
                    OK thanks. I'll have a quick look at what I have at the moment.
                    '93 Audi UrS4 Avant
                    • hunker7
                      • Mar 2014
                      • 3487
                      #265
                      Now I know why I need a wideband, one I have now is a right pain in the back side. Goes from lean to rich, never stops. This is where I am now, if 2nd and 3rd point is moved up, it's too rich, down, it goes lean.
                      Petrol ms 2.9 on petrol
                      Petrol ms 2.1 on gas
                      '93 Audi UrS4 Avant
                      • diesel des
                        • 3896
                        #266
                        Bring the point that says 3.9 down to the left so it's at 2 on the x axis. And about 2.5 on the y. Try that
                        • hunker7
                          • Mar 2014
                          • 3487
                          #267
                          Will do tomorrow, thanks
                          '93 Audi UrS4 Avant
                          • prj
                            • Mar 2010
                            • 6308
                            Do not make any decisions off of that. EVER. It means nothing, especially when closed loop control is turned on in the ECU.
                            • hunker7
                              • Mar 2014
                              • 3487
                              #269
                              OK thanks. Just trying to get it as good as I can for now, till I get wideband
                              '93 Audi UrS4 Avant
                              • hunker7
                                • Mar 2014
                                • 3487
                                #270
                                Moved the point and petrol ms stays the same pretty much on both petrol and gas. No check engine light either.
                                '93 Audi UrS4 Avant
