Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #226
    I tried messing with 2nd and 3rd points and it's nothing and then suddenly it starts shaking
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • hunker7
      • Mar 2014
      • 3487
      #227
      Also swith over to gas is nice and smooth, gas to petrol rpm jumps up is that OK?
      '93 Audi UrS4 Avant
      • hunker7
        • Mar 2014
        • 3487
        #228
        Was filling her up today, and when i removed the filler there was gas coming out of the filling point?
        Looking at booking safety test in next week, can that be done at any company that does lpg fitting?
        '93 Audi UrS4 Avant
        • diesel des
          • 3896
          #229
          Some small amount of gas will come out at full up that's normal. You need to talk to the Lpg assessor to see if he is happy to test your car.
          At light loads your Motronic runs closed loop so small changes of the gas map will not appear to do anything. But the goal is to try and get Motronic adaption to zero with no adaption limit errors.
          • diesel des
            • 3896
            #230
            The rpm jumping is likely to be due to mixture adaption taking a while to catch up. Have you the lambda connected yet? That would help You see if it's going rich or lean when it switches.
            • diesel des
              • 3896
              #231
              Show a pic of your map now.
              • hunker7
                • Mar 2014
                • 3487
                #232
                I'll call some places near me on Monday than and see who could get her tested
                On gas petrol injector ms is 2.5ish and when I switch to gas it jumps to 3.2, so I just need to get them both matched and that should take care of that. I've connected lambda, but honestly that thing is all over the place on idle, can't really tell much.
                I'll get that tomorrow, as it's pissing down atm
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #233
                  Ok your mixture on idle is also too rich. Bring it down some and try again.
                  At least the car is driving ok for you on gas now and just needs fine tuning.
                  After making adjustments to the modeling you should really clear the points it has gathered and reset the petrol ecu so it can learn new points with no adaption.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #234
                    Sorry meant to say on gas petrol ms is 2.5 and when I switch to petrol it jumps to 3.2.
                    Clear the map points? I think it asks to clear both gas/petrol map after changes are made. So when I'm done with modeling part I just reset petrol ECU so it can learn it all again?
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #235
                      Yep that's it. Each time it gets closer to exactly were it should be.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #236
                        This is how it looks like at the moment.
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #237
                          And how is it driving? Motronic happy yet?
                          • hunker7
                            • Mar 2014
                            • 3487
                            #238
                            Feels very good. Boosts just fine, idle is pretty good, feels better than petrol if I'm honest. Still need to get petrol ms to stay the same when switching over, currently when running on petrol it's 3.1 and when on gas it's 2.1, so it shakes when switching back to petrol.
                            If I leave it as it is now, can it do any damage? I have exams coming up and final project to finish and don't have loads of time on my hands
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #239
                              It should be fine. Don't be doing any 24 hour endurance races.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #240
                                Not planning on. Couple of hours drive at the time max
                                '93 Audi UrS4 Avant
