Those who run LPG converted 2.2's
Oh remember the vacuum nipple needs connected to the intake manifold after the throttle. Put a t on that hose and run the third part of the t to the sensor for intake pressure.
Also the heat pipes need t'd into the hoses going to the heater matrix. Don't connect in series. I think you need 2 water t pieces that are 20mm on the through side of the t and 16mm for the vaporusor. But check. Also worth getting them in brass or copper. I don't like the plastic ones.
Sent from my LG-H955 using TapatalkComment
There should be a sensor on your vapourisor or at least a pocket for it to go into? Or maybe now it's a separate sensor that the water flows through?
That's the gas solenoid. You will have another one similar that goes at the gas tank end.
Yea I think the vapourisor has an insert or a place for the water temperature sensor. Unless they have changed. Ask your supplier. I have an old kme gold I will look at tomorrow and picture what I mean.
Here are some pictures of a old one gold. Note the nipple\ thermo pocket for a temp sensor.
I could send you this screw/nipple but you need the small sensor to which I don't have. Contact your supplier and ask them if they carry those parts. They could be a separate pipe with a sensor in it now?
Nothing comes with diagrams which is quite annoying.
