Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #121
    Originally posted by diesel des
    5mm goes to gas pressure sensor. Or if your sensor is in line then block them up. They can be filled with weld.
    Is it this one?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • diesel des
      • 3896
      #122
      Think that one measured gas pressure that flows through it and temperature. The nipple on it is for inlet manifold pressure connection.
      • hunker7
        • Mar 2014
        • 3487
        #123
        So it goes between reducer and one if the injector manifolds? Does that mean I don't need sensor in the reducer?
        '93 Audi UrS4 Avant
        • diesel des
          • 3896
          #124
          That's a water temp sensor in the reducer do you need that too.
          • hunker7
            • Mar 2014
            • 3487
            #125
            Got it. So this is gas pressure/temperature sensor, and it can be on either of the manifolds?
            '93 Audi UrS4 Avant
            • diesel des
              • 3896
              #126
              Yep. After the filter
              • hunker7
                • Mar 2014
                • 3487
                #127
                Would this do for my KME Diego g3 ecu?
                Lead for connecting ECU controller with diagnostic computer software. Suitable for LPGTECH, KME and iother ECUs.
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #128
                  That should be fine.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #129
                    Where did you put you ecu?
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #130
                      It's just in the engine bay near the abs modulator. The kme vapourisor will fit right above the abs and the ecu to the side.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #131
                        How about water and things? Could you take some pictures, or have any?
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #132
                          My setup is different now as I have 2 vapourisor and have them positioned down were the stock intercooler is. Ivan byd1380 had added some pictures of his which is a single vapourisor setup.
                          • diesel des
                            • 3896
                            #133
                            Post 37.
                            • hunker7
                              • Mar 2014
                              • 3487
                              #134
                              I think that is what I'll do, and possibly mount ecu where POS used to live.
                              '93 Audi UrS4 Avant
                              • hunker7
                                • Mar 2014
                                • 3487
                                #135
                                Des, you need one of these
                                Leisure gas, RV, autogas and LPG tanks, bottles parts, conversions systems for cars, campervans, campers, motorhomes, forklifts and homes.
                                '93 Audi UrS4 Avant
