Those who run LPG converted 2.2's
  • diesel des
    • 3896
    #166
    Yep it's kinda cool. Good luck should be fine.
    • hunker7
      • Mar 2014
      • 3487
      #167
      It shows that pressure is too low or tank is empty?
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #168
        As soon as it reaches 25C there is a click from the tank and it says about pressure being too low. Do I need more lpg in the tank?
        '93 Audi UrS4 Avant
        • diesel des
          • 3896
          #169
          Check that has is leaving the tank by cracking the pipe fitting up near the vapourisor. If no gas check the manual valve is open if you have one. Then check after the vapourisor near the injector rail to see if gas is present. Is solenoid on vapourisor getting power. Could be wireing to solonides if no gas or pressure sensor if gas is there.
          • hunker7
            • Mar 2014
            • 3487
            #170
            There is gas at the vaporizer, and solenoid seems to be wired up too. There is a blue-black wire and blue-red wire on the redicer solenoid where do I connect blue-red wire? I have it as ground currently
            UPDATE: It now switches to gas, but it starts stalling and juddering. Looking at the readings tab, it looks like it doesn't switch petrol injectors off? I get readings for both injectors.
            '93 Audi UrS4 Avant
            • diesel des
              • 3896
              #171
              It will turn the petrol injectors off once it transions to gas. It does one cylinder at a time. You now need to start the calibration process. Autocal is now a good starting point. What readings have you for gas pressure when it tries to run on gas. Have a look at lambda when you switch over. See if it goes rich or lean and also look at petrol ecu durations to see if motronic is adding or taking fuel. Once calibrated motronic pulse time will not change when swiching to gas as the gas flow will equal the petrol flow.
              Take a pic of the calibration map. What nozzles are in the magic jets.
              • hunker7
                • Mar 2014
                • 3487
                #172
                Pressure is about 0.9 bar.
                So it's ok that it runs pretty rough at the start? It also shows load, and load on petrol injectors increased as soon as i switched to gas.
                Should I start calibration process when it's fully running on LPG?
                Magicjet came with screw in nozzles that I left in, should I take them out?
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #173
                  Yes if it's increasing the injection times than it's likely to be lean. Remove the restrictions and try again. I think you start the calibration process with it on petrol. Follow the on screen instructions. Do it with lights and all electrical loads off. Then it asks to increase load. Turn all lights on air con on full and put steering at full lock etc. This is from memory. Its so the ecu sees 2 different operating points to scale itself against.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #174
                    Thanks. I'll take out the injector inserts and get car upto temperature (reducer needs to be 50C to start AutoCal), I assume I have to override the auto switch over at 25C?
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #175
                      If you use the button in the car to keep the gas off Then start the Autocal. That should do it.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #176
                        OK thanks mate, I shall try it tomorrow and hopefully it will go as planned
                        If I remove cables etc later I don't have to calibrate it again?
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #177
                          That's correct it remembers. But back it up to your laptop just in case.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #178
                            Will do. Thanks, I'll report back tomorrow
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #179
                              Cool. Once you get your head round what's happening it's actually quite simple. Just stick with it.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #180
                                It's probably because I don't know what to expect, so when car starts juddering and stalling you don't know what to do
                                '93 Audi UrS4 Avant
