Those who run LPG converted 2.2's
  • diesel des
    • 3896
    #136
    Originally posted by hunker7
    That does look cool.
    • prj
      • Mar 2010
      • 6308
      2.7 bar outlet pressure, useless.
      • diesel des
        • 3896
        #138
        That will be with reference to above intake pressure. So I only run 1 bar on mine and have enough gas to fuel my stroker.
        • hunker7
          • Mar 2014
          • 3487
          #139
          Trying to fit tank atm, and I've hit a bit of a problem. Inlet is 8mm for which I've bought copper tube, but outlet that goes to the reducer is 6mm(outside diameter), instead of 8mm (outside diameter). FARO fitting is 8mm so I can't fit it?
          Do I just order FARO fitting with 6mm diameter?
          '93 Audi UrS4 Avant
          '15 Audi A7 quattro 3.0 TDI
          • diesel des
            • 3896
            #140
            You can get an adapter.
            • hunker7
              • Mar 2014
              • 3487
              #141
              How are they called?
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #142
                Something like this? http://pages.ebay.com/link/?nav=item...601770&alt=web
                • hunker7
                  • Mar 2014
                  • 3487
                  #143
                  Thanks mate, that's been ordered. Dad is making injector mounting plate over weekend.
                  '93 Audi UrS4 Avant
                  • diesel des
                    • 3896
                    #144
                    You might need a short length of 6mm copper too. Just to go from the tank valve to the adapter.
                    • hunker7
                      • Mar 2014
                      • 3487
                      #145
                      Dad will try and find one at work
                      '93 Audi UrS4 Avant
                      • hunker7
                        • Mar 2014
                        • 3487
                        #146
                        Can I have ECU connected and working without having tank connected? I have to order connection for tank to reducer pipe but I have to be back in Leeds on Sunday, so I could finish it off there, least I could do is finish off soldering.
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #147
                          Yep that's fine. The way loom needs fitted and the gas ecu then the car will run on petrol normally.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #148
                            Thanks Des, I'll crack on with soldering then
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #149
                              Just make sure it's the signal wire at the injector you tap into not the 12v feed.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #150
                                I'll check it with multimeter before
                                '93 Audi UrS4 Avant
