Those who run LPG converted 2.2's
Trying to fit tank atm, and I've hit a bit of a problem. Inlet is 8mm for which I've bought copper tube, but outlet that goes to the reducer is 6mm(outside diameter), instead of 8mm (outside diameter). FARO fitting is 8mm so I can't fit it?
Do I just order FARO fitting with 6mm diameter?'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Something like this? http://pages.ebay.com/link/?nav=item...601770&alt=web
Sent from my LG-H955 using TapatalkComment
You might need a short length of 6mm copper too. Just to go from the tank valve to the adapter.
Can I have ECU connected and working without having tank connected? I have to order connection for tank to reducer pipe but I have to be back in Leeds on Sunday, so I could finish it off there, least I could do is finish off soldering.
'93 Audi UrS4 Avant
Yep that's fine. The way loom needs fitted and the gas ecu then the car will run on petrol normally.
