Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #196
    Originally posted by diesel des
    Yep. Then fine tune that graph. It allows many points to be adjusted. In just trying to get you almost these with multi
    There is first time for everything I guess
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • hunker7
      • Mar 2014
      • 3487
      #197
      Had a play with Modelling tab and at times it got better, but honestly I have no idea what either of those variables mean or do to how car runs.
      Gas pressure seems to be low as well, about 0,7bar?
      After doing Autocal, what's the best way to collect the map points?
      '93 Audi UrS4 Avant
      • diesel des
        • 3896
        #198
        The modeling tab allows you to adjust points across the operating range of the engine. From memory the x axis is the gas injector duaratuon and the y axis is the petrol duration. So I find at idle the petrol duration is shorter the gas duration. E.g. 3 ms petrol and maybe 4 ms gas. Then at light load the petrol ecu light be at 5 ms and the gas at 6.5 ms. Then at high loads say 18ms petrol I find the gas is less e.g. 15 ms maybe. You can pull up and down the points inn the graph to get it exactly how it needs to be at all points. Without the wideband lambda it will be harder to tell if it's lean on rich but your stock lambda once connected will help.
        Basicly what you want when your inn the measure screen is about 1 bar gas pressure. Then when you switch between petrol and gas the motronic Times should stay the same. If the motronic Times get bigger you need to increase the point on the model curve up in the y position to give more gas. Then try switching again between petrol and gas and see if the times on motronic stay the same. Now repeat at a higher load setting.
        • diesel des
          • 3896
          #199
          If you find the gas times are all much more than petrol times increase the multi. If they are all much less reduce multi.
          • diesel des
            • 3896
            #200
            Then you need to adjust all your model points again. After a multi adjust.
            • hunker7
              • Mar 2014
              • 3487
              #201
              Gas pressure is never at 1 bar, it is about 0.7-0.8 range most of the time?
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #202
                Adjust the reducer to get 1 bar. There is an Alan key on top. Set 1 bar also in your ecu and try again.
                • diesel des
                  • 3896
                  #203
                  Oh I see gas is tg on the y axis and tb is petrol time on x
                  • hunker7
                    • Mar 2014
                    • 3487
                    #204
                    So I start with Autocal WITH and WITHOUT load
                    Then should I get map point or calibrate it?
                    When I calibrate it, do I move P1 or P2 around?
                    So if Motronic ms goes up when switching to gas, I increase Tg (up in y direction), if Motronic ms goes down, I decrease Tb?
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #205
                      Autocal can go 2 ways. One is a good setup that drives ok and the other is how yours seems to be which is bad. I try auto cal again and if it's crap reload what you have now and start adjusting it yourself as described.
                      • diesel des
                        • 3896
                        #206
                        I don't think you need to play with p1 or p2
                        • diesel des
                          • 3896
                          #207
                          Your on stock petrol injectors right? You could try the restrictors back in your gas injectors again then.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #208
                            Stock injectors yes. I will get the pressure up to correct value and try auto calibration again and see where that takes us.
                            So the red points are the ones I move up and down as required?
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #209
                              Yes the red dots on the graph on modeling page. It does look like the calibration has leaned off your gas a lot. I think smaller nozzles will help.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #210
                                OK, I will do that tomorrow and see if that makes it better
                                '93 Audi UrS4 Avant
