Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #151
    Can I get rid of the wires coming out of injector manifold?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • diesel des
      • 3896
      #152
      They are for gas temperature. Do you have another sensor for this? I would keep one as a spare.
      • hunker7
        • Mar 2014
        • 3487
        #153
        I have inline one as in picture in post 121
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          #154
          She runs ok now with LPG ecu. But I am not sure about several wires as to where they should go. Brown-White goes to Ignition coil minus pin, does it matter which ignition coil and why it needs to be there? Solid Violet doesn't seem to be on the wiring diagram, where should that go? (Both wires are together with positive/negative wire)
          White green wire isn't connected to anything, as I don't have mechanical level reader? I have brown and blue wire coming from solenoid valve on multivalve, so blue wire in picture below connects blue coming from multivalve, and brown is earth?
          wires for 6th cylinder just doesn't get connected?
          Wiring diagram I used
          Hope it all makes sense.
          '93 Audi UrS4 Avant
          • diesel des
            • 3896
            #155
            Yep don't worry about 6th injector. Brown white goes to a pos driver wire e.g. from the ecu output side. Doesn't matter which coil.
            That pink pilot wire which pin on ecu connector does it goto?
            Have you no level sensor in your tank? That's what the green white connects to.
            Blue to gas valves sounds right. Is Brown at tank the level gauge? Measure it out on ohms to ground on the tank.
            • hunker7
              • Mar 2014
              • 3487
              #156
              I have multivalve with floaty, and it comes with a black solenoid valve to which 2 wires connect? This is the one I got.
              Leisure gas, RV, autogas and LPG tanks, bottles parts, conversions systems for cars, campervans, campers, motorhomes, forklifts and homes.
              I'll have to check tomorrow which pin it goes to, as I don't know from top of my head, it's on the grey connector.
              Brown is minus on the solenoid valve?
              I'll do some pictures tomorrow
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #157
                If the multivalve only have 2 wires and it has a gauge then one is for valve and other is for gauge. Those valves have no polarity but I would use Brown as ground.
                • hunker7
                  • Mar 2014
                  • 3487
                  #158
                  On the actual valve it says - and +, so I connected blue to positive and black to negative.
                  '93 Audi UrS4 Avant
                  • diesel des
                    • 3896
                    #159
                    Or Brown to negitive but sounds ok
                    • hunker7
                      • Mar 2014
                      • 3487
                      #160
                      I meant brown yeah.
                      Since fitting inlet manifold back and other lpg stuff car is slow to respond, but once she responds she runs fine? Any ideas? No error codes, and I've checked everything twice.
                      '93 Audi UrS4 Avant
                      • diesel des
                        • 3896
                        #161
                        Gas setup should of made no difference. Must be some other sorta issue.
                        • hunker7
                          • Mar 2014
                          • 3487
                          #162
                          I know, and it boosts to 2.4 too.
                          Also, I checked where violet goes and it's pin 5A in grey plug.
                          '93 Audi UrS4 Avant
                          • diesel des
                            • 3896
                            #163
                            Gas temperature then. N75 connected ok?
                            • hunker7
                              • Mar 2014
                              • 3487
                              #164
                              Pressure+temperature gauge that's in-line has a plug and pink-blue wire that's it, there is no violet anywhere else that's the only spot.
                              Don't know tbh, does seem like something is wrong with boost control.
                              '93 Audi UrS4 Avant
                              • hunker7
                                • Mar 2014
                                • 3487
                                #165
                                I can get used to this Calibrating tomorrow, wish me luck.
                                '93 Audi UrS4 Avant
