Those who run LPG converted 2.2's
Take a screen shot of the screen that shows duty cycle and rpm when on petrol and then repeat on gas. Have you the narrow band lambda sensor connected?
Sent from my LG-H955 using TapatalkComment
Grey connector 4a. Connect it to the wire that comes drink the sensor that is between 0 and 1 volts. Normally 0.45 at idle.
It looks too lean. Increase gas pressure and try. Motronic is increasing its ms so it's wanting more fuel in gas as gas setup is lean.
How does it drive now. This is where a wideband kit is good.
Try increasing and decreasing the multi to see how idle changes
Multi tap. Its a crude way of scalling up and work the complete map. At minus 40 your leaned off a lot.
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Yep. Then fine tune that graph. It allows many points to be adjusted. In just trying to get you almost these with multi
or MULT tab in #181 second screenshot?
