Those who run LPG converted 2.2's
  • hunker7
    • Mar 2014
    • 3487
    #271
    Also found couple of leaks I've missed, and soap water didn't pick up but all sorted now.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • hunker7
      • Mar 2014
      • 3487
      #272
      Well, never mind, check engine is still on. Is it possible that it doesn't run properly because it's just not properly set up?
      '93 Audi UrS4 Avant
      • diesel des
        • 3896
        #273
        You have the idle set correctly now by the sounds of thinks but I still think your not range settings are off slightly. You need to get a friend to sit and watch the timings while crusing at steady speeds on petrol and compare with gas times.
        • hunker7
          • Mar 2014
          • 3487
          #274
          OK, I will try and get ms for petrol and gas @ 60,70,80mph
          '93 Audi UrS4 Avant
          • hunker7
            • Mar 2014
            • 3487
            #275
            Managed just under 200 miles on full tank, so I am not a happy bunny. I will have my girlfriend record petrol/gas ms @ 60, 70, 80 mph in 4th, 5th and 6th gear, and then we can try and get it sorted.
            '93 Audi UrS4 Avant
            • diesel des
              • 3896
              #276
              How many liters is that? It can be a little inconsistent sometimes as the tank shutoff valve can shut down early depending on how level the car is while filling.
              • hunker7
                • Mar 2014
                • 3487
                #277
                I did 197 miles on 47 liters, which works out as 19 mpg. I'm expecting something in the region of 24mpg. I did 150 mile drive and got a similar mpg last week.
                '93 Audi UrS4 Avant
                • diesel des
                  • 3896
                  #278
                  19mpg still sounds ok to me.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #279
                    That's 30% higher consumption in comparison to unleaded, which I think is too much. I get 27mpg on unleaded with about 3/4 of tank on motorway and 1/4 around town.
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #280
                      I have never got over 25mpg on petrol. But maybe it will improve once all the settings are dialed in.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #281
                        Mine is only stage 1 mapped. I am going for a drive tomorrow night, so 4th 5th 6th gear at 60 70 80mph should do?
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #282
                          Yep need to get the higher ms times trimmed in too.
                          Even stock 25mpg seems good.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #283
                            OK I'll get that done tomorrow. On unleaded it runs much smoother, still trying to find out what is causing sluggishness
                            '93 Audi UrS4 Avant
                            • hunker7
                              • Mar 2014
                              • 3487
                              #284
                              Went out to take measurement and took petrol on petrol but didn't record petrol on gas, instead got petrol and gas
                              '93 Audi UrS4 Avant
                              • diesel des
                                • 3896
                                #285
                                Doh
