Those who run LPG converted 2.2's
  • Kieron20V
    • Mar 2008
    • 1505
    #346
    The innovate one i mentioned has a wire to tap into the light circuit so it dims the output when you have the lights on at night so it's not so bright. Not too intrusive really, but i ran mine in one of the aux gauge positions on a coupe.
    Sent from my Nexus 6P using Tapatalk
    1994 URS4 Avant RS2+
    • hunker7
      • Mar 2014
      • 3487
      #347
      that's useful to know, thanks
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #348
        Got this in the post today So what do I do with it now (apart from fitting) and what can I do with it?
        '93 Audi UrS4 Avant
        • Kieron20V
          • Mar 2008
          • 1505
          #349
          Lob it in....
          • hunker7
            • Mar 2014
            • 3487
            #350
            Lob it in....
            Won't be able to do till after 5th Should finish my 3rd year project first
            '93 Audi UrS4 Avant
            • hunker7
              • Mar 2014
              • 3487
              #351
              While trying to chase down problems with running, I noticed that LPG ECU has recorded "fuel injector fully open" error? And LPG seems to be misfiring, but all injectors are working?
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #352
                Fuel injector full open errors are common enough. Probably just a momentary thing that it logged.
                Isnt it messing arround on petrol too? Something is up. Done a compression test recently?
                • hunker7
                  • Mar 2014
                  • 3487
                  #353
                  No misfires on petrol, just jumping revs occasionally, but I assume that's just mapping.
                  I don't think it's compression, starts too well and ticks over smoothly on petrol.
                  Wide band is going in this weekend so I'll get an idea of how she's running
                  '93 Audi UrS4 Avant
                  • hunker7
                    • Mar 2014
                    • 3487
                    #354
                    Just went for a quick drive and runs fine. While engine was heating up at one point all the lpg injectors just started opening very quickly, so switched the engine off and turned back on and was all good? Don't know what is going on.
                    '93 Audi UrS4 Avant
                    • diesel des
                      • 3896
                      #355
                      What do you mean they were opening quickly? Did it just change over to gas while you watched it? It does one cylinder at a time over maybe 2 seconds.
                      • hunker7
                        • Mar 2014
                        • 3487
                        #356
                        I could hear solenoid clicking really quickly as if opening injectors, but it was still running on petrol.
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #357
                          The one at the tank or?
                          • hunker7
                            • Mar 2014
                            • 3487
                            #358
                            No, the actual injector, I touched them and could feel solenoid working.
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #359
                              It must of being changing over to gas then.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #360
                                When I turned off the engine, started again, it didn't switch for a while. I'll keep an eye on it, and see if it's one off
                                Quick question, where did you put lambda plug? Bosch I have is pretty thick and I don't know how to get it in the car
                                '93 Audi UrS4 Avant
