Will do thanks. On idle it's around 0.85bar.
Those who run LPG converted 2.2's
Been looking at filters, I currently have these ( http://www.lpgshop.co.uk/12mm-to-12m...ur-gas-filter/ ), would these be any better ( http://www.lpgshop.co.uk/12mm-to-12m...-paper-insert/ ) or it doesn't really matter?'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
'93 Audi UrS4 Avant
I have never needed to change the liquid filter. Its always clean when I check it. The vapour filters do get dirty and restricted though.
Sent from my LG-H955 using TapatalkComment
'93 Audi UrS4 Avant
Bad news. New filters and pressure increased to 1bar and same problem. Car does not jerk around like it was when my ignition wasn't upto job, it just doesn't have fuel. Anything else I can check? Looked at injectors and they work fine.Attached Files'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
All or just the end one? And by how much?
It didn't happen saddenly though, went for a drive and on acceleration I occasionally felt it pull back, but I'm known to be paranoid so didn't think anything of it. On way home I ran out of gas, when I filled up that's when it got really bad.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Just the top dot. Pull it up a bit and try again. It an take a while for the injectors to settle in.
