boost lag and fuel economy question
I might have found issue in regards to my boosting problem, I mean I found out the hard way, currently sitting and waiting for my brother to tow me back home.
R.I.P. Fuel Pump'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Stick a new fliter in too
It's not the fuel pump after all, sparkplugs are all wet so it isn't getting spark, I got TFSI coils. Can't connect laptop as it says Port Status OK interface not found'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Check wirig of coils, especially the ground which is bolted to the motor.Comment
Wiring is good, and all the earth cables are attached and connections cleaned.
What could cause the blue smoke coming from the exhaust, looked like someone was pouring oil in the exhaust. Oil level hasn't dropped.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Ecu dumping in fuel for some reason? possibly boost hose split?
Have you had the plugs out on the cam cover? see if it's sparking?Comment
I started car in the morning it started and stalled straight away, then I tried starting again and revved it, and it came to life, and then blue smoke was coming out of exhaust, I left it to tick over for a while and it was all fine.
Then I was going home and it was all good, when I felt that car looses power slightly every now and then, and then felt that some cylinders were not working, 2 by the feel of it, and smoke was pouring out then. After I stopped car was running on 3, then I turned it off and couldn't start back up again.
I will check the spark in a minute.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Hate to say it but I think you should check the timing again. At the flywheel, make sure iut hasn't moved.
Could you have a loose chip in the ecu or the ecu connector not seated properly?Comment
Injector failed?Comment
I dont have experience of this, post a new thread.. "Car broke down - cylinder 2 full of fuel" or something like thatComment
I guess it's floodedComment
