Have you replaced the lambda sensor that's also another thing I have changed in the past.
boost lag and fuel economy question
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
It boosts fine, and when it does it shifts like hell, but it's just that it only kicks in at 3000 and above.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
By "on boost" you mean full boost? At 2500 mine only starts boosting
basically my 7000 is much laggier than your 7200 and you get more at the end of it
I don't know, I'm using dash one. I don't think I get higher than 1.5 around town at any time under normal driving.
'93 Audi UrS4 Avant
Mine is chipped so I'd expect it to come little earlier. Because if you say starts building at 2500 then mine is like that, but then takes upto 4000 to be on full boost.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Disconnect the N75 and see if it's different.Comment
Should do, just to check it behaves normallyComment
Have you still got the stock chipset?Comment
