For 300 Hp you will be fine, particularly as it is such a short run
AAN in T3 Syncro 16 - misfire above 10psi boost
Originally posted by Greg_S View PostFor 300 Hp you will be fine, particularly as it is such a short run
My biggest problem now is finding a rolling road with a door that's 3 meters tall...
MG
So a package arrived this morning...
No cracks
I'm trying to put together a package that will give me 300bhp with 300ftlbs reliably and doesn't have to run on 98 octane fuel the whole time. This is a camper after all and we can end up anywhere in it and need whatever fuel is around.
MG
Originally posted by Greg_S View PostI would change the exhaust manifold first as it is towards its limits around 300HP
My turbo seems happy enough and the engine doesn't smoke.
Again, I'm only looking for 300bhp/300ftlbs and would prefer the power to start at lower rpms as it's in a 2,500kg 4WD Camper.
MG
Well, I've decided to re-hash the exhaust system and I'm starting with a 3" downpipe.
Has anyone used one of these?
I'm planning on using two 3" silencers in series. The first may end up being a 'two-into-one' straight through design and I'll cap the single outlet off for daily running and have the gasses turn 180Ā° and then into another 3" silencer. It needs to be a sensible volume! I'll put a valve on the outlet of the first silencer so that it'll open up on 3/4 throttle or something similar.
MG
Originally posted by Greg_S View PostThe stock k24 with home fries is a really good compromise. I remember someone using the 2871r a few years back with that criteria which worked well
That RS2 exhaust manifold will help things in either case.
- 1 like
I've decided to upgrade the lot while I'm in there...
My K24-7200 has just landed. It came up at a good price and I wanted something that I just fit and forget.
So now I have the RS2 EM, Turbo, larger injectors, socketed ECU and I'm collecting parts to build a 3" exhaust.
I'm not that happy with the step up in size from the flange to 3" so I've got a nice cone coming to replace it and get a smoother flow.
All pipes on the silencers are 3"
The first silencer is a twin to single.
I'll run the feed pipe into one of the twins and there will be a valve on the single outlet which will stay shut below say 70% throttle. That way, when just tootling around, the exhaust will double back going out of the other twin, and then over to the second silencer which is an offset 3" in/out.
On throttle above 70% with the valve open, it'll be straight through.
MGLast edited by RS2; 12 February 2018, 16:02.
Reading up on FPR, the AAN has a 4.0 bar unit.
Is it worth fitting an adjustable version for fine tuning or am I just asking for trouble?
Like this...
https://store.034motorsport.com/fuel...k-fitment.html
MGLast edited by RS2; 14 February 2018, 11:51.
Adjust your base fuel pressure and you'll have to adjust your tune accordingly.
Haven't read the thread yet, just clicked on it... but already seems like the best idea ever!Last edited by PRY4SNO; 15 February 2018, 04:26.Find me on Instagram @pry4sno
2010 Golf Sportwagen TDI /// #farmenwagen
2002 Dodge Ram 2500 24v Cummins 4x4
Biggest thing is actually having the smoothest exhaust pathway. No sharp bends.
Also, this might prove handy for sizing your exhaust.
Originally posted by PRY4SNO View PostBiggest thing is actually having the smoothest exhaust pathway. No sharp bends.
I've seen a few graphs now which are similar and they all have different results.
I'm going from the experience of people here and my friends who run rolling road dynos with the 3" system.
I understand that a straight flow path is the best but unfortunately in the space that I have with it mounted in the back of the van (****** all!) I don't have a choice about where the exhaust can go.
The Turbo is facing the wrong way to start off and I use the vehicle off-road so I can't have it slung underneath.
MG
What a cool project! Could we please have som pics of the van itself, and the enginebay? Wonder why VW never fit a more powerful petrol engine in these things.
Originally posted by fish View PostWhat a cool project! Could we please have som pics of the van itself, and the enginebay? Wonder why VW never fit a more powerful petrol engine in these things.
This was when I was testing a set of 2.0 TFSI coil packs. The engine ran worse on these than on the original setup (it was detonating) so I've gone back to the original coils now and it's happy on high octane fuel.
MG
