Coil Packs Misfire
    ok. So if i use the 1.8T coils instead once I have worked out how to fit them to the camcover and make sure the leads reach the plugs properly how are they wired?
    at moment each coil has two wires to them which are a decent gauge and an earth connected to the coil cover.
    How are the 1.8T coils wired? what would need to be changed? from what I understand the two amps on the bulkhead would become redundant and the input to those would then go to each seperate coil? then what else is required?
      Ive started to re wire the coils as a temporary measure until I work out how to do the 1.8T coils since 3 out of 5 coils the insulation is breaking off right as it goes into the coil and ive taken one apart a little tonight but there isnt a way of reliably rewiring that close :-(
      I got a quote from vag parts and they are 90.75+VAT & P&P so 1.8T's looks surprisingly attractive now.
      • S2sedan
        • Aug 2004
        • 189
        #33
        lee,
        Can you please explain me how to hold the 1.8 t coil packs at aby engine ???
        I have misfire probl. at high gear under boost.
        Eduardo
        S2 Limo sold !!!
        M5 E34 with some mods in the garage
        sorry, but much happeir now !
          you have to put studs into the cam cover to mount them to and trim a bit of the coil pack off of the one that goes in by the oil filler cap.
          • audiman
            • 4827
            I will try and take apicture of Grant Parkers AAN engined golf at GTi International.
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
              I took a couple of pics last year. Just been checking some part numbers. I could do with knowing how the 1.8T coils are pinned out and what the pins to ignition amps are etc and what the 1.8T coils will need.
              • audiman
                • 4827
                They are the same coils on as Becky's A4, three wires on each one. Not sure what they are, it uses 2 POS AFAIK. But thats only 4 cyls mind!!
                Audi UR Quattro
                  Just had a look and it looks like those ones use a seperate output stage part no 8D0 905 351. Is becky's an AEB engine?
                  • audiman
                    • 4827
                    Yes sir it is! What a beast
                    Audi UR Quattro
                    • Baldy
                      • 469
                      • Home: Sikkim Current: British Antarctic Territory
                      #40
                      u mean like that sorta thing
                      Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                      0-60 4.9
                      1/4mile 13.5
                      • kwlw
                        • Sep 2004
                        • 1025
                        • Country: Lithuania
                        #41
                        This is golf ?
                        You kidding right ?
                        I can suspect that this thing is RWD or AWD. Am I right ?
                        Sau
                        P.S. It's 03:40 am, and I'm still working
                        • martinjs
                          • 3205
                          Yes, 4WD.
                          very fast
                          • S2sedan
                            • Aug 2004
                            • 189
                            #43
                            thanks for thje reply guys ... one more question, once they are phisicaly installed, are those plug and play, or require some wiring mods ?
                            S2 Limo sold !!!
                              They will definately need some wiring mods. I havent worked out exactly what needs to be done yet but with A4 coils just changing plugs i think. with 1.8T re wire without ignition amps on baulkhead too.
                              • S2sedan
                                • Aug 2004
                                • 189
                                #45
                                OK Greg thanks, let me know when you are done, I`will try to do that if I could not sell my sedan before ...
                                S2 Limo sold !!!
