Coil Packs Misfire
  • Doug_RS2
    • 3847
    Paul - a lot of old flukes have the conductance measurement on them - It is not something I had ever noticed or used until I needed it for the coilpack measurements.
    • BRY
      • 3755
      Does anyone know if the coil packs for the Porsche 996 will work in the aby?
      I read a post where someone had fitted BMW coils so I thought these may be worth a go.
      Part number - 996 602 102 00
        got any other part numbers for them?
        Ive take the coils out of the car again to take alook at the cables going to the coil packs the insulation on them is well baked and cracked in places. One of the coils has the insulation broken just as it enters the coil. There is a rectangular plastic cover over where the cables go in.
        What im trying to find out is what is underneath this cover, and if i take it off will it be ok without it? since the plastic is breaking off that too from where it has been baked so much. I would get some pictures but cant find digi cam
        ta
          IVe managed to find a picture now, not a very good one mind.
          • Lee
            • 1512
            You can make 1.8T ones fit. Not too hard and you only need to shave a bit off the one for number 2 cylinder to get it to clear the oil filler cap. Can't use the standard coilpack cover then...you wouldn't need it anyway as the 1.8T coils need to be bolted to the rocker cover instead. They are dead cheap and feature built in Power Output Stages too.
            I would do this if it were my car and I was looking for new coils.
            Designun Limited....
            • BRY
              • 3755
              #21
              @Greg_S
              0 040 100 021
              BERU
                Originally posted by audiman
                Stay out of it!!!! No chance. Watch out for a std looking 3b coming up behind you soon!!! It might be me
                Yeah, 3B technology, you know it makes sense..
                A badge on the front would work, then ABYers would know what was about to overtake them
                • Lee
                  • 1512
                  LOL. We'll see!
                  • mreinders
                    • 72
                    • Home: United Kingdom Current: Netherlands
                    #24
                    almost makes me wish they did an aby with a distributor (not)
                    oh, the old days
                    010100110011001000101111010000010100001001011001
                    011000100011010101010011001101000100000101110110
                      Id rather not have to replace all of them if i can help it because it will also mean having to fit studs into the camcover to screw the coil packs to and also which leads would be used so they still fit onto the spark plugs?
                      What im still trying to find out though is if i break off that little plastic cover and re wire the coils will it matter that the cover isnt there?
                      • iain1067
                        • 984
                        The 1.8T coil packs do have a habit of failing or did, i spent the last 5 years in the dealer network and the amount of these we replaced was unreal.
                        Iain
                          yeah i remember hearing about that. I had a pic of the dubwieser mk1 golf with coils and they were different from the 1.8t ones but not sure which they were or how they fitted em.
                          any idea with the plastic cover for cables on the S2 coils tho?
                          • audiman
                            • 4827
                            That problem wasnt only on 1.8T, they have now sorted that problem out and the new ones are behaving!! At last.
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              #29
                              110k miles on the 1.8T and no coil problems. Well, only that a professional didn't plug one in properly. They all got renewed because they’re so cheap, and it was hardly worth finding out which one was causing the trouble.
                              SS
                              • audiman
                                • 4827
                                Grant Parker uses the older type 1.8T coils like the ones on Becky's A4. These cause no problems until very high mileage
                                Audi UR Quattro
