ok. So if i use the 1.8T coils instead once I have worked out how to fit them to the camcover and make sure the leads reach the plugs properly how are they wired?
at moment each coil has two wires to them which are a decent gauge and an earth connected to the coil cover.
How are the 1.8T coils wired? what would need to be changed? from what I understand the two amps on the bulkhead would become redundant and the input to those would then go to each seperate coil? then what else is required?
